10-21-2007
Best Looking Moderator
I had the RL and Color version on my previous boat. THere is no comparrison between them and the E series. I have also had the Garmin on a different boat. I liked the Garmin a lot, but still opted for the E series.
To answer your question, the ability to turn down the E to a readable level without hurting your night vision is easy to do and much better than the previous models. It also scrolls, refreshes, overlays, and in general runs better.
If you are used to the RL series, you will be able to run the E series pretty easily as it is basically the same thing, but with a few refinements in pages. The only thing I have found that I do not like on the Raymarine series is when you lose a HS Bus it really screws everything up... and not just the unit that loses the buss. Do all manufacturers have this problem??? I don't know. Most of my experience is with Raymarine. But I would not rule out the Garmin either. They make a nice product and it is pretty easy to navigate.
- CD
PS Just one comment on night vision: I have found that CP's (esp color) all screw up your night vision. Not sure there is a way around that. You can turn it down so it is very dim... but it still eats at the night vision.
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Are you trying to talk your spouse or family into cruising or sailing? Want to know what it is like, every day? Click here and enjoy: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
