Old 10-21-2007
rchad is on a distinguished road
Yanmar throttle
The throttle cable on my Yanmar 2GM20F is very difficult to move. I disconnected it from the engine and found that the problem is not with the cable linkage but with the arm that connects to the engine itself. Why is the arm so difficult to move? Any help would be appreciated.
Old 10-21-2007
USCGRET1990's Avatar
SENIOR CHIEF
USCGRET1990 is on a distinguished road
Those arms sometimes only move easily when the engine is running...
Old 10-22-2007
Yanmar Throttle
The speed control arm is difficult to move whether or not the engine is running.
Seems to work just fine, just seems that it should operate much more easily. I have to put a lot of muscle into increasing and reducing throttle.
Old 10-23-2007
trantor12020's Avatar
trantor12020 is on a distinguished road
Is there a drag device on the throttle cable ? Is it always like this ?
Old 07-18-2011
swanwick is on a distinguished road
Update?
rchad,
Curious, how did you solve your problem with the throttle arm on the engine?
Old 07-18-2011
Irrationally Exuberant
arf145 is on a distinguished road
The throttle control for our Yanmar on our Edson column has an adjustment screw inside to vary the resistance. However, it has to be set with a lot of resistance to keep the throttle from creeping down on its own. So, I don't consider the difficulty moving it as a problem so much as a solution.
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 07-18-2011
Liquorice's Avatar
Liquorice is on a distinguished road
I have a 2GM20F and the throttle is perfectly fine.
I have never had a problem so there must be a solution.
sam :-)
Just because you're paranoid ...doesn't mean they're not after you!
Old 07-19-2011
rpearlberg is on a distinguished road
question about yanmar throttle...
on a Pearson 303 with an Edson Pedestal, in order to "go" i have to hold the throttle all the way forward, it won't stick by itself, unless I tie a rope around it. How can I fix this?
Old 07-19-2011
norsearayder is on a distinguished road
tighten the brake screw to increase drag on cable to hold her open ,loosen the screw if friction is too much.dont forget to tighten lock nut after adjustment
Old 07-19-2011
is the brake screw near the engine, or in the pedestal where the lever connects?
Yanmar 2mg20 ThunderFog Gear & Maintenance 8 1 Week Ago 06:25 AM
Need help YANMAR engine mount Giulietta Gear & Maintenance 20 04-15-2010 01:15 PM
Yanmar 4JH2E air filter element garyroot Gear & Maintenance 8 03-30-2010 08:23 PM
Smoke on the Water - Yanmar Question DrB Gear & Maintenance 7 09-04-2007 05:31 PM
Prop for Morgan OI w/ Yanmar 3GM30F cwarwick Gear & Maintenance 1 11-16-2004 01:17 PM
