TackTick Instruments - Page 2 - SailNet Community
post #11 of 15 Old 10-23-2007 Thread Starter
Wind, depth, speed and temperature data doesn't really require a high data rate. If you think about it.... updating the wind speed, direction, water speed, depth, and temperature is only a few bytes of data total.
sailingdog is offline
post #12 of 15 Old 11-08-2007
Gary M's Avatar
I think the Tic Tac are really nice but I had not thought about any lightning issues? However I have fairly new Raymarine depth and speed instruments so I am looking at Raymarine wind instruments.
I believe that if I go with them then I can hook up the speedo to the wind instruments I can get true wind and direction?
How is the Raymarine quality and service? I think I have heard here that it is not the greatest.
Thanks
Gary
Gary M is offline
post #13 of 15 Old 11-08-2007 Thread Starter
Raymarine's service is spotty...sometimes they're quite good, and others you gotta wonder. I had the ST60 gear on my boat, and got rid of it. The problem wasn't the hardware itself from what I've been able to tell, but the wiring.
post #14 of 15 Old 11-08-2007
Larus Marinus
Idiens's Avatar
SD - Any idea how many TACKTICKs can share the same marina without interfering with each other?
Idiens is offline
post #15 of 15 Old 11-08-2007 Thread Starter
Considering that some charter fleets have taken up using TackTick instruments, as have some boat manufacturers, I don't think it is much of an issue. The main problem you'd have with other boats in the marina having TackTick instruments is when setting up an installation. You'd have to be far enough away to not have the instruments accidentally network to an adjacent boat. This is also the case if you're adding displays. Aside from that, I don't think there's much of a problem.
UK & Netherlands. Tacktick to launch Wireless Maxi range for large ... - BYM News (press release) NewsReader News Feeds 0 11-02-2006 06:15 AM
UK & Netherlands. Tacktick to exhibit new Micronet Power Boat Wind ... - BYM News (press release) NewsReader News Feeds 0 11-02-2006 04:15 AM
Suggested Instruments... newuser Gear & Maintenance 8 11-10-2005 12:29 PM
Reflections on Cruising Instruments Tom Wood Seamanship Articles 0 08-31-2004 09:00 PM
Instruments shuttdh Gear & Maintenance 1 01-21-2004 09:58 AM
