- Quick Menu
10-23-2007
Ancor Terminals: the must haves
So, I'm going to rewire my DC panel (and maybe run some new wires) on my Catalina 30, and I thought I should put together a terminal / connector kit (rather than make 40 trips to West Marine).
I know it's hard to generalize, but what are the must haves, in terms of terminals....the 20% of the connectors that one uses, 80% of the time.
I found a 600 piece kit on Amazon, but again, why pay for connectors you're never going to use?
Would love to hear from those of you who have been down this road before.
thanks,
tom
10-23-2007
Aquaholic
Hooked spades, for each gauge of wire, are ok; but whenever possible I recommend ring terminals. In order for them to come off the entire screw has to come out of the connection, something you will like be alerted to through intermittent electrical problems long before it becomes completely disconnected.
Some heat shrink tape or tubes is also a must have, to cover any butt-crimps you need to do.
Oh, and spend the money for a good quality stripper/crimper; don't cheap out and buy a dollar store one, spend the extra 5 or 6 $ and get a good one, you'll be glad you did.
Fred
I got an Old Fat Boat
She's Slow But Handsome
Hard In The Chine, but Soft In The Transom
I Love Her Well, And She Must Love Me
But I think It's Only For My Money
. ..... Gordon Bok
10-23-2007
Thanks, Fred.
On the butt connectors, should I get the thru-pipe kind, AS WELL AS the closed on one side, kind? Also, how about the step-up or step down connector?
Also, how many gauges should one get?
On the ring terminals, it seems like they have a zillion eyelet sizes.
10-23-2007
Finally found the needle!
Along the same line of thought, what is a good price to pay for, and where is a good place to find, a quality racheting crimper? I have seen ratcheting crimpers from Paladin for ~$40, but they require that you buy a die for an additional $20. Sixty bucks is more than I want to spend on a crimper.
10-23-2007
Don Casey, who is in my eyes, the god of all boat know-how, says that racheting is better, but typically, impractical away from the workbench. (e.g., upside down in the crawlspace)
10-23-2007
I bought all my terminals at Harbor Freight. You can also get the stripper and crimper there as well.
Order the shirnk wrap from Tiewraps.com . Be sure to get the kind with the adhesive.
Use vaseline for dieletric goop.
It's all much cheaper this way. Some will argue the quailty. Fro me it has worked great.
10-23-2007
Definitely want the adhesive lined heatshrink tubing.
Avoid spade terminals... you really need ring terminals and butt splices.
The spade connectors are pretty useful, especially if the female ones are insulated properly. I use these for making up polarized connections for electronics that I can remove.
I'd second Harbor Freight.
10-23-2007
Hey, guys, do you use the general terminals (e.g., not Ancor brand), or the generics? I can't find the Ancor brand at Harbor Freight.
thanks for info.
10-23-2007
Wandering Aimlessly
On my boat, I use #10 14-16ga (blue) ring terminals the most. Also the 1/4 and 3/8's ring. Anything larger than 10ga wire, you most likely will need a rather larger crimper. Home Depot (if your local store has a marine wire section) has great prices on Ancor products.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love. JCP
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - Website & Blog
10-23-2007
Blues and Reds are the one I use most.
Rings that will go around a 1/4 inch bolt and ones that will go around a # 10 screw seem to fill 90 percent of my needs.
Boats-cars-motorcycles
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Must Haves On Board?
babykinz |
herSailNet |
152 |
03-17-2009 12:02 AM |
