10-24-2007
Just another stop...
The Simplest things are hard...
Well, this may sound stupid, but....Anyone have a good trick for getting the *%*$#^& nut off of the **^((* bolt? I am removing stanchions for deck refinishing and on three separate base plates there is one stinking nut that I cannot break loose. I am setting vice grips on the nut below and honking on the screw head with the biggest screw driver the slot will take. I have applied WD-40 to the nuts. I wire brushed them in case there was some kind of corrosion holding them. No Joy. My next thought is a sawzall. Any other ideas before I get powered up?
Thanks,
Freeman
