10-24-2007
Holding Tank and Winterization
Good Day All!
I had my Holding tank pumped out, and then just before the boat was pulled from the water, I learned that my family decided to use the head. Grrr.
I am told it was only #1, however in your collective experience, with maybe 2 flushes of the system and a 28 Gallon Holding tank, could I cut a corner and just add the pink stuff to the system.
Obviously, as I am saying "Cutting Corners" I know I shouldn't do this, and I know the concept of a boat = pit in the water to which you through money.
However, their charges to pull the waste once the boat is on land is 150$.
I am doing the physics of at most 1 gallon of water waste in a 28 gallon space and the cost of adding 2 gallons of pink stuff versus 150$ for a pump out.
Thoughts..
Ian Lyons
Sea Lyons
2002 Hunter 326
Ian Lyons
Sea Lyons
Hunter 326
Narragansett Bay
