10-24-2007
ASA and PSIA Instructor
Originally Posted by kwaltersmi
The project boat I'm working on has what I believe are wire-to-rope halyards, but the ropes are missing. I also think the halyards were rigged to over the coach roof and back to the cockpit as evidenced by the bullseye fairleads and turning blocks on the coach roof. However, I've never actually seen this boat rigged.
The boat is a 1972 Helms 25. What size halyard rope (length & diameter) do you think I should use? How is this determined?
Thanks!
(I need to stop logging into this forum...I'm learning wayyyy too much about sailing.)
You need to start with nothing bigger than whatever size line will fit in the sheaves installed in the mast, and whatever turning blocks are used. Don't mess with wire-to-rope, get all rope. Change the sheaves if they are for wire. I would doubt that a boat this age originally came with halyards to the cockpit, so if it is setup that way, some PO probably has changed everything at some point. Call the staff at www.layline.com if you want good advice on high tech line. As to length, add 10 feet to the estimates above so you can secure the jib halyard to the bow pulpit and the main to the rail, so they don't slap the mast all night, and have some working length left over.
Is there a winch for the jib halyard somewhere?
