Old 10-25-2007
sailing320's Avatar
sailing320 is on a distinguished road
Generator Sound Shield
Does anyone know where I can have a generator sound shield made? I currently have a blanket over my generator and it is still loud. I'm looking for something that is sound proof!
Old 10-25-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
Sailors Solutions has a couple of things that may work. www.sailorssolutions.com
S/V Scheherazade
Old 10-25-2007
O'day 26
joeybkcmo is on a distinguished road
not sure if it will work for you, but when we go camping we have a small "box" made out of the thick foam insulation you can pick up at home depot, dont want to make it too air tight, air flow is always good
Old 10-25-2007
camaraderie's Avatar
moderate?
http://www.acousticalsource.com/boat-soundproofing.html
should do the trick.
Old 10-25-2007
henrygermond is on a distinguished road
suggest lining the compartment with lead foil-backed foam. you could google
for products. the air intake manifold is also a source of noise. but putting a blanket on the beast is probably going to hurt the cooling of the engine. the
compartment needs to be ventilated to the outside. the supplier of the unit
may have some good ideas.
Henry Germond 25 Oct 07
Old 10-25-2007
There are several products made for lining the engine compartment to reduce the sound levels that get out... any one of these would probably work quite well for your generator compartment.
Shuttle to check heat shield, deploy satellites (Reuters via Yahoo! News) NewsReader News Feeds 0 12-20-2006 02:15 AM
tedlar shield for racing sail chris1f Racing 6 01-12-2003 05:05 PM
Keel Shield Tom Wood Gear and Maintenance Articles 0 09-14-2000 08:00 PM
