10-26-2007
Last Grumpy Old Sailor
Another weighted solution, albeit somewhat more expensive than milk jugs, would be a variation on what I used to use on my inverted-V and long-wire antennas. They were anchored to trees--the inverted-V at its apex and the long-wire at each end. The problem was how to keep the antennas reasonably tight yet allow the trees to move. Solution: A pulley (a block, to you sailors  ) and a bucket with holes drilled in the bottom for water drainage, filled with the desired amount of rock for weight. The line on for the inverted-V was tied to the apex and ran around the pulley above. The line for the long-wire was simply fastened to one end, with the pulley secured to the tree. Worked like a champ.
I plan to run line through the tarp, under the boat, from side-to-side, as USCGRET1990 suggests.
Jim
s/v Abracadabra
1976 Pearson P30
