Old 10-26-2007
claritycal36 is on a distinguished road
How much should a re-engine cost??
Folks,
I have a quote from a boat yard on a new Yanmar 3JH4 with V-Drive and was wondering if anyone has had a boat yard pull your old engine and install a new one. Round about figures would be appreciated of what folks have spent.
Old 10-26-2007
chucklesR's Avatar
Gemini 105Mc Hull 987
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
Clarity
It all depends on the boat - labor makes up a big part of it and some boats are easier than others. On mine, the Westerbeke 30b drops into the center cockpit locker - prob take 6-8 hours total.
Folks, include boat type, estimated and actual costs to make it real.
My dock mate put a Yanmar 18hp in his Hunter 28.5, estimate was 4,500 US, actual was 4150, in 2004. Reduction in cost based on me helping for 8 hours.
Old 10-26-2007
JimsCAL's Avatar
JimsCAL is on a distinguished road
If the yard is doing all the work, figure labor at about equal to the cost of the bare engine. Don't know the specifics of that Yanmar, but I am guessing $8000 to $10000 for the engine, so I would estimate $16,000 to $20,000 for the entire job. Labor rates vary quite a bit around the country, so you could be above or below my very rough estimates. If you can remove the old engine and/or do some of the system hookup of the new one yourself, you can save a lot of money.
Old 10-26-2007
ASA and PSIA Instructor
$5k assuming you put the same model engine in. This figure included new mounts, hoses, insulation, muffler, etc.
Old 10-26-2007
teshannon's Avatar
teshannon has a spectacular aura about teshannon has a spectacular aura about teshannon has a spectacular aura about
a lot of it depends on what it takes to get the old engine out and the new one in. It almost seems that some boats were completed after the engine was installed a removing it involes a lot of disassembly/cutting. I think the $20k estimate is realistic for those scenarios.
Old 10-26-2007
SF's point about mounts, hoses, insulation, etc.. is a very good one. If the new engine is the same as the old one, the costs should be a good deal lower, since you don't have to do any modifications to the engine bed, or spend time installing new motor mounts and such.
However, as the others have pointed out... the exact make and model of boat will have a lot to do with the cost of the installation. Some boats are far easier to work on than others... and have lower costs to do a re-power.
Old 10-26-2007
dave6330 is on a distinguished road
$16-20K? Does that include the engine itself?
Old 10-26-2007
teshannon's Avatar
Dave,
I would guess $10k for the engine and the rest for installation.
Old 10-26-2007
Wow!!! Here's hoping I don't ever have to go down that road. I think I'll elevate PM on my priority list!
Old 10-26-2007
teshannon's Avatar
Dave,
I once considered buying a Bristol 41 that needed a new engine. I got that estimate as part of the negotiation but ultimately did not buy the boat. The cockpit floor would have had to be cut out the remove the old clunker. Not something I would want to get into. PM is definitely the way to go.
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 08:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 07:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 07:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
