Old 10-26-2007
l0keman's Avatar
l0keman is on a distinguished road
bench/bed foam
Where can I get the foam I see in this picture? This picture is from west marine and is selling the cloth dry bunk stuff underneath it.
I am after a thick foam like this that can be cut to size/shape.
Old 10-26-2007
USCGRET1990's Avatar
SENIOR CHIEF
USCGRET1990 is on a distinguished road
Probably anywhere that makes or reupholsters furniture. But the darn stuff can be real expensive. Be aware, foam is made with variing densities.
Old 10-26-2007
You should look for a foam distributor... most major metro areas will have at least one. What you want is a fairly high-density open cell foam. Closed cell foam won't absorb water, but it gets clammy—since it doesn't breathe very well either.
Old 10-26-2007
eherlihy's Avatar
Finally found the needle!
eherlihy is on a distinguished road
That looks like closed cell foam. THere are a slew of companies that sell it. Look in almost any sailing or boating magazine to find some vendors. Here is one to get you started http://www.bottomsiders.com/.
You don't say what you need it for, but many of the companies will custom mold it to your needs.
Ed
Old 10-26-2007
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
Some time ago I had designed and built a custom livingroom set for my home. Did everything myself, including the solid maple frame, selecting & cutting various grades of foam wrapped in polyester, a resilient spring system and all fabric cutting, sewing and upholstering - quite the project.
I learned a few things about foam, but basically use a medium, to medium-firm density HR (High Resiliency) foam for seat cushions and a softer grade for back cushions. I actually used a firm core for the seats with a medium-soft layer folded over, then wrapped in polyester batting. All fabric was removable with brass zippers. Purchased the fabric and foam supplies from an upholstery supply distributor/manufacterer in Providence, RI.
True Blue . . .
sold the Nauticat
Old 10-26-2007
pegasus1457's Avatar
Arf!
pegasus1457 is on a distinguished road
memory foam
I am having back problems and just transitioned from a good quality conventional mattress (at home) to a memory foam system (sold by Tempur-Pedic). It has really made a difference in my ability to sleep through the night.
So I was inspired to do something similar for the V-berth cushions. I looked at the "mattress topper" pads marketed by Tempur-Pedic and found the prices to be outrageous. I started looking on the web for memory foam and found that many sources sell pads either 2" or 3" thick in various sizes. A piece large enough for a twin bed is much less than $100 from several sources. (Look for memory foam and then "mattress topper.")
I plan to remove the existing foam and use it as a template to cut the new memory foam (same thickness as the original).
Has anyone done this?
Old 10-26-2007
TrueBlue's Avatar
Señor Member
I also have a sometimes re-occuring lower back problem and decided to upgrade our forward stateroom berth. We found an economical source of memory foam in 4" thickness' (actually from one of those Job-lot places). I bought the King size which came with a quilted cover that zipped up into a "bag" to enclose the whole mattress.
I cut the foam to the exact shape of the V-berth with an electric carving knife, cut the cover, resewing on the diagonal to suit and simply keep it in place over the existing upholstered berth mattress shapes. Makes for a very comfortable bed.
True Blue . . .
sold the Nauticat
Old 10-26-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
I went with 5 inch memory foam for the sitting/sleeping cushions.
S/V Scheherazade
Old 10-26-2007
Pogo-2's Avatar
Pogo-2 is on a distinguished road
memery foam
I bought the memory foam from Wally-Mart 8" thick queensize for $239, I'm going to keep it on my bed at home for the winter and if I like it like everyone says I will then I'll cut it to fit the V birth on my Newport 30. Since I plan a lot of cruising this summer it should take care of my back problem from sleeping om the 4" regular foam pad. I'll let you all know how it works out this summer.
Old 10-26-2007
dhornsey is on a distinguished road
We also did something similar. Replaced our v-berth cushions with 4 inches of medium density foam, topped with 2 inches of memory foam. Great results. Costco sometimes sells the memory foam toppers at a very reasonable price.
I *highly* recommend using an electric carving knife to cut either memory foam or normal foam. Any other method we tried looked like it was done by a 2 year old.
Good luck.
Building a Rudder Newport 30 Armchairprotest Gear & Maintenance 5 04-07-2009 01:11 PM
Mildew Smell! Windermere Gear & Maintenance 22 09-25-2007 07:06 PM
replacing foam in berth cushions wumhenry Gear & Maintenance 14 09-13-2007 10:55 AM
PVC foam core rbh1515 Boat Review and Purchase Forum 2 01-08-2004 09:35 AM
Sound Insulation Foam Sue & Larry Gear and Maintenance Articles 0 01-31-2002 07:00 PM
