Old 10-26-2007
kwaltersmi's Avatar
Broad Reachin'
kwaltersmi is on a distinguished road
Best wood-to-wood adhesive
I'm planning to make new companionway door slats next week out of a couple of pieces of marine plywood I have left over from another project. In order to replicate the thickness of the current companionway slats on my sailboat I'm going to need to use adhere the two pieces of marine plywood together. What's the best adhesive for this?
Old 10-26-2007
JimsCAL's Avatar
JimsCAL is on a distinguished road
My choices would be Titebond III waterproof wood glue or perhaps Gorilla Glue. Either should work well.
Old 10-26-2007
Epoxy would work pretty well too.
Old 10-26-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
I would also cut some strips of wood, that would look like a planned design but could also be the area where you add brass or stainless screws to aid in holding everything together.
S/V Scheherazade
Old 10-26-2007
deniseO30's Avatar
Lies about her age
Walter the difficult part of laminating plywood onto plywood is getting it all pressed together without voids. You may want to do allot of prep work before you glue it. We used boards across the short width and planed a slight crown on the edges. then we clamped them edge to edge with the plywood in between . The wider it is the more difficult it is.
good luck
Old 10-26-2007
Using Gorilla Glue, which expands as it cures, or thickened epoxy would help prevent voids.
good luck
Old 10-26-2007
AjariBonten's Avatar
Aquaholic
AjariBonten is on a distinguished road
I absolutely love West System epoxy for this type of project. Gorilla glue is very good too, but I have had better luck using GG on solid wood projects.
Slightly thickened West is fantastic, and fills any voids.
I got an Old Fat Boat
She's Slow But Handsome
Hard In The Chine, but Soft In The Transom
I Love Her Well, And She Must Love Me
But I think It's Only For My Money
..... Gordon Bok
Old 10-26-2007
bobmcgov's Avatar
baDumbumbum
bobmcgov will become famous soon enough
I vote epoxy, though with that much surface nearly any glue from TB2 to mastic to earwax would serve. Denise is right -- clamping is the tough part. Cauls help, or a press of some sort. Absolute best method is vacuum-bagging, which can be faked pretty well with some visquene, a ShopVac, and a compressor-driven venturi pump. The glue squeezeout won't stick to the plastic.
If using cauls, wax em or cover them with wax paper, saran, or duct tape. Or you may find your new hatch has a few unintended battens attached!
Buccaneer18, Grainnia
SJ21, Diarmuid
Old 10-26-2007
waltpm is on a distinguished road
I have laminated three pieces of 1/4 in plywood into a 3/4 in piece using epoxy and it has lasted about 5 years so far and still looks perfect. If the pieces are to big to clamp, (mine were)then make sure that the pieces are flat and weight them on a flat surface. BTW, a recent issue of Fine Woodworking evaluated glues, and Gorilla Glue came out dead last in almost every category including strength.
Old 10-26-2007
Here .. Pull this
Sailormann will become famous soon enough
I have found that Gorilla Glue REALLY expands quite a bit. It's certainly strong but I would think that it's going to be difficult to get an even bond between the two pieces. I would go with epoxy or resorcinol.
Rot: the basics (small boats) InlandGirl Boat Review and Purchase Forum 4 09-17-2007 10:06 AM
Seeking advice on taking care of some exterior wood. Northbeach Gear & Maintenance 6 05-16-2007 03:43 PM
Adhesive for deck superdave Gear & Maintenance 5 03-30-2007 10:19 PM
Soft/Rot Wood on ply in bilge. Rasputin General Discussion (sailing related) 3 06-22-2001 05:01 AM
Soft/Rot Wood on ply in bilge. Rasputin Gear & Maintenance 3 05-11-2001 10:30 PM
