Old 10-29-2007
GBurton is on a distinguished road
Prop sizing
Does anybody know the formula for prop sizing?
Thanks for any help
Old 10-29-2007
capngregg's Avatar
Shaken-not Stirred
capngregg is on a distinguished road
Cool
If you're into calculus it can be a great exercise to determine the proper characteristics for a propeller for any given boat. There isn't any simple formula to produce that information.
There are lots of software programs out there to solve the problem www.hydrocompinc.com is one site or you can call the manufacturer to get the original installation for your vessel. If you're re-engineing, typically the engine/transmission guys have software they will run your boat information through to come up with a "recommended" prop for your installation.
If you're just experiencing prop performance problems in general there are all kinds of propeller repair sites that offer basic formulas to vary engine RPM based on prop pitch, cup, rake, diameter and so on. Usually your local prop guys can recommend changes based on your information.
Good Luck,
Gregg
Opportunity is missed by most people because it is dressed in overalls and looks like work.
T.A.E.
Old 10-29-2007
Tartan34C will become famous soon enough
It’s a book not a formula. One good one is written by Stanton and published by Cornell Maritime Press and the other standard work is written by Dave Gerr. Stanton is specific to sailboat propellers and Gerr is a general propeller book. Most texts on design also have a chapter on propeller selection with Skene’s Elements of Yacht Design being the easiest one to understand. What do you want to know? By the way most propeller shops and all propeller manufacturers will make a recommendation if you give them a call.
All the best,
Robert Gainer
Study the history of naval architecture and move forward knowing what didn’t work before.
Don’t waste time making the same old mistakes but instead make new ones and to insure your place in history be sure the mistakes are big ones.
Never design a mast that is weaker then the boat
Never design a boat that is weaker then the mast
Never listen to someone describe why your project will not work unless they can show you the broken pieces of their own version.
Old 10-29-2007
JohnRPollard's Avatar
Moderator
In addition to the good suggestions above, I would also poll other Westsail 32 owners to see what they are using as an engine/prop combination (assuming this question is for your new boat).
Old 10-29-2007
Thanks for all the help! I guess I was oversimplifying it a bit.
I was under the impression that if you had LWL, weight, engine HP and torque it could be easily done.
The engine that I plan to use (Bukh) is not common over here in the States so I need to plan from scratch.
Old 10-29-2007
It’s somewhat of an art and not straightforward at all. The shape of the area around the propeller and in fact the shape of the hull will affect the slip of the prop as just one factor. That factor alone makes a great difference and if you have a Westsail 32 the slip is considerably greater then on a Person Flyer for instance. The idea of checking with the Westsail forums is a good one and you might want to start there. You can get enough information to calculate the slip from other boats and use that to enter the formulas to calculate for your own engine. It doesn’t matter who made the engine the only thing that matters is the HP, RPM’s and propeller pitch and diameter. And the slip is the same for a given hull and all engines/ propeller combinations and only varies by the shape of the hull.
The diameter is clearly related to HP and RPM’s so that’s easy to figure out. The pitch is controlled by slip and the shape and number of blades and the RPM of the shaft.
Good luck and all the best,
Robert Gainer
Fixed vs Folding Prop doons60 Gear & Maintenance 11 07-29-2007 08:27 PM
Zincs for Sail Prop feathering prop jrbarn Gear & Maintenance 4 09-20-2006 10:40 AM
Max prop on a saildrive levenezia Gear & Maintenance 16 09-20-2006 12:07 AM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
Choosing a Prop Sue & Larry Gear and Maintenance Articles 0 12-24-2001 07:00 PM
