Bukh engines - Page 2 - SailNet Community
post #11 of 34 Old 10-29-2007
I understand that they are Swedish. I have seen one of them, a twin. It looked well-built, but probably with expensive spare parts.
The triple will be inherently better balanced than the twin. Triples are polular on motorcycles for that reason.
Rockter is offline
post #12 of 34 Old 10-29-2007
Originally Posted by GBurton View Post
Is there a recommendation for HP/LBS of boat?
Like most quick rules of thumb this number, pounds per HP needs some common sense to use effectively. The amount of horsepower expressed this way varies quite a bit with length. And surprisingly it decreases as the boat gets larger. The best way to look at it is compare similar boats and in your case compare to other Westsails 32’s.
If you want the base numbers to draw a chart start with,
500 pounds per HP equals a speed length ratio of 1.3
1,000 pounds per HP equals a speed length ratio of 1.05
1,500 pounds per HP equals a speed length ratio of .95
2,000 pounds per HP equals a speed length ratio of .85
If you select 2 HP per 1,000 or 1 HP per 500 pounds you can expect a speed length ration of 1.3 which is high for a Westsail 32 but let’s go with that number and work it out, so with a waterline length of 27.5 feet you can expect a speed of 6.8 knots. This is all based on shaft horsepower not advertised power.
All the best,
Robert Gainer
Study the history of naval architecture and move forward knowing what didnít work before.
Donít waste time making the same old mistakes but instead make new ones and to insure your place in history be sure the mistakes are big ones.
Never design a mast that is weaker then the boat
Never design a boat that is weaker then the mast
Never listen to someone describe why your project will not work unless they can show you the broken pieces of their own version.
Tartan34C is offline
post #13 of 34 Old 10-30-2007
Robert...
What am I misunderstanding?
How does one get a figure of 6.8 from the two figures 27.5 and 1.3 ?
My ship weighs 23,000 lbf, and I have about 35 hp (Volvo say). What speed should I expect? The ship is a double-ender... a Union 36.... with a big footprint in the water and a wetted length of 33 ft, apparently.
Rockter is offline
post #14 of 34 Old 10-30-2007
JimsCAL's Avatar
I am sure Robert (as a Naval Architect) can explain this much better than I can (being a Marine Engineer), but I suspect he calculated the hull speed using an equation like:
Hull Speed (kts) = 1.3 to 1.4 X Square Roof of Waterline Length (in feet)
Hull speed in a displacement (non-planing) hull is when the resistance due to wavemaking basically limits further speed increases. Below that speed, the frictional resistance dominates. The very rough rule of 2 Hp per 1000 lbs generally provides sufficient power to get to hull speed plus a little margin.
JimsCAL is offline
post #15 of 34 Old 10-30-2007
OK, so it's 1.3 (say) times the square root of waterline length.
I got it.
Rockter is offline
post #16 of 34 Old 10-30-2007
Splashed
JomsViking's Avatar
They are Danish, not Swedish. And due to rotating counterweights they do not vibrate much. I have a new (2004) DV24ME and really love it compared to the Volvo's and Yanmar's I've seen. But I've only owned boats with Volvo's (and no engines) before. One of my friends installs these in rescue boats WW and is VERY proud of the product, which was one of the reasons for me to choose that engine (having your own mechanic is also great )
Watch great footage about the story of one manís slow odyssey around the UK:
JomsViking is offline
post #17 of 34 Old 10-30-2007 Thread Starter
I have found out that Bukh sells a turbocharger for the DV24 (The engine that I have) This might solve the problem that I have with the engine being too small for my boat (Westsail 32)
What are the pros and cons of turbocharging a sailboat engine?
GBurton is offline
post #18 of 34 Old 10-30-2007
The downside is shorter engine life and more likelihood of unexpended failure. I donít feel the need for very much power on a sailboat and in fact sometimes sail without an engine of any kind. Maybe you should try the boat before changing things.
All the best,
Robert Gainer
post #19 of 34 Old 10-30-2007 Thread Starter
The thing is that the engine is not installed. I have to make the decision on whether to install the engine or not.
GBurton is offline
post #20 of 34 Old 10-30-2007
tdw
Super Fuzzy Moderator
tdw's Avatar
What's you displacement ?
Raven is 34' displaces about 8 tons in the old imperial scale, 7 tonnes metric.
Relatively easily driven hull, fin keel.
Our Bukh DV24 is quite sufficient for our needs. Yeah, maybe I'd go up in size if buying a new one but its basically cool as. No turbo. We run a three bladed fixed prop btw. Would prefer folding but can't be bothered to pay the dosh.
Andrew B (MalŲ 39 Classic)
ďLife is a trick, and you get one chance to learn it.Ē
― Terry Pratchett.
tdw is offline
VOLVO PENTA ENGINES Bryant Gear & Maintenance 22 06-26-2011 05:18 PM
Range of Small Engines when motoring...only. PapillonDory General Discussion (sailing related) 6 06-02-2007 01:32 PM
Diesel & Gas Engines? oceanmaui Gear & Maintenance 5 10-24-2004 07:40 PM
The Great Stroke Debate Tom Wood Gear and Maintenance Articles 0 03-31-2003 07:00 PM
The Great Stroke Debate Tom Wood Cruising Articles 0 03-31-2003 07:00 PM
