Bukh engines - Page 4 - SailNet Community
post #31 of 34 Old 03-13-2011
sctpc's Avatar
I know this is an old Thread but Im very concerned,
I have a Bukh 10hp and yesterday I got caught in a squall on port Phillip bay and tried to run her at 2700rpm and could only get 2200rpm and oil, fuel was coming out the exhaust, its like she has no power. Starts fine, idles but puts out black stuff and I cant get up the revs. suggested adjusting stop solenoid what do you guys recon is it a major problem and should I get a mechanic to look $$$ or be tight and run it till something happens!!! I do prefer option 1 but would like to have an idea first.
sctpc is offline
post #32 of 34 Old 03-13-2011
Check that your prop and boat bottom is clean!
Most likely unburnt fuel due to overloaded engine.
haffiman37 is offline
post #33 of 34 Old 03-13-2011
mitiempo's Avatar
If the prop and bottom are clean suspect the exhaust elbow. The exhaust is as important as the intake and if restricted by carbon build-up, which is common, the engine will do exactly as yours does.
Brian
mitiempo is offline
post #34 of 34 Old 03-14-2011
sctpc's Avatar
Thanks Guys That would be it I dident check the prop or bottom this week as in two weeks im anti fowling it, and I haven't used it for 3 week ether.
sctpc is offline
VOLVO PENTA ENGINES Bryant Gear & Maintenance 22 06-26-2011 06:18 PM
Range of Small Engines when motoring...only. PapillonDory General Discussion (sailing related) 6 06-02-2007 02:32 PM
Diesel & Gas Engines? oceanmaui Gear & Maintenance 5 10-24-2004 08:40 PM
The Great Stroke Debate Tom Wood Gear and Maintenance Articles 0 03-31-2003 08:00 PM
The Great Stroke Debate Tom Wood Cruising Articles 0 03-31-2003 08:00 PM
