battery performance - SailNet Community
post #1 of 2 Old 04-09-2002 Thread Starter
battery performance
I may have battery problems and need an expert. I have two Trojan 8Ds for house use, giving me 432 A/H. Last weekend the system went down to 12.14 volts and was only 150 A/Hs down and my refrigeration started to have trouble starting with the low voltage. I think I should be able to use 216 A/Hs (50% of capacity) before getting low voltage problems, right, otherwise why carry the extra weight of an 8D? Or maybe I''m missing something, here.
larrywa is offline
post #2 of 2 Old 04-10-2002
battery performance
Hi
You must remember that when a motor starts up, it requires 3-5 times as much current. Therefore, it is imperative that the battery voltage remain high. Also, there is an inherent discrepancy in all meter readings from 2-5 %, depending at what point of the scale the needle is reading the meter.
Joe
jhanay is offline
Solar Power for Battery Charge KnotaClew23 Gear & Maintenance 1 09-23-2005 04:40 PM
battery isolator with starter/generator? owenmccall Gear & Maintenance 1 07-21-2004 08:58 AM
Starter or House Battery? rrobar Gear & Maintenance 2 12-30-2003 04:56 PM
Battery combiner vs battery isolator prelude General Discussion (sailing related) 2 07-09-2003 09:31 AM
Wiring set-up for battery switch. pehrst Gear & Maintenance 6 06-18-2002 06:51 PM
