Electrical upgrade - Page 2 - SailNet Community
post #11 of 21 Old 11-02-2007
moderate?
camaraderie's Avatar
Hoffa...sorry but that is not right. Wet cell batteries can only take about MAXIMUM of 20% of capacity during bulk charging which means that a 60amp altenator is fine for a 300ah bank.
Even with charging system loss...fully charging is simply a matter of time. Incomplete charging can happen with ANY size charger and is definitely a problem if you don't monitor what is happening in your charging routine.
He does not need a bigger or better alternator cause the boat will be MOST of the time at the dock and the charger will put on a proper charge and EQ when needed. Nothing bad is going to happen to his batteries in a week of cruising with a standard regulator even if he doesn't pull into a dock. Why spend an extra grand on a big alternator/regulator and install if you don't need it?
AGM batteries can take unlimited current and a 100amp range alternator would be more appropriate for those if a quick charge was needed. (Note: Going too much over 100amps on most sailboat engines causes bearing wear and creates a whole 'nother set of problems to deal with to insure that wear does not occur...otherwise you could add a 300 amp alternator for AGM's if you weren't worried about the horsepower loss!)
camaraderie is offline
post #12 of 21 Old 11-02-2007
Of course with anything larger than an 100 Amp alternator, the size of the cables starts to become an issue.
sailingdog is offline
post #13 of 21 Old 11-02-2007
Semper Gumby
GySgt's Avatar
Send a message via MSN to GySgt
bestfriend- If you are still at Alameda let me know and I can help you install/watch/drink your beer/learn or mess things up for you
GySgt is offline
post #14 of 21 Old 11-02-2007
A very generous and self-less offer...
post #15 of 21 Old 11-02-2007 Thread Starter
Hitchin' a ride
bestfriend's Avatar
Thanks gunny. I still live in Alameda, the boats in SF. Would love to have you aboard, i'll keep you informed. You could hang out, drink beer, and jab me with the forespar right when I get really frustrated! We were supposed to go out yesterday, but if you noticed, it was pea soup and no wind. Trying to go out again next week, maybe monday, if you are up for it, I will drop you a line or PM me with your phone number.
Great men always have too much sail up. - Christopher Buckley
Vaya con Dios
bestfriend is offline
post #16 of 21 Old 11-02-2007
Here .. Pull this
FWIW my boat came with Surette wet cells that are 8 years old and still going strong. They charge quickly. I think they sell them as Rolls in the states.
Sailormann is offline
post #17 of 21 Old 11-02-2007 Thread Starter
Hitchin' a ride
bestfriend's Avatar
Thanks, SM. I need to check the cells before I give them up for dead. Maybe just a better charging system will fix the problem. Not sure what brand mine are.
Vaya con Dios
post #18 of 21 Old 11-02-2007
moderate?
Sailormann...yep...Rolls/surette...excellent batteries and priced that way!
post #19 of 21 Old 11-02-2007
Here .. Pull this
Don't take offense at this, but you did top them up with distilled water eh !
...I'm thinking that if they last ten years then it might be cheaper to buy them than to replace others every two or three years...
post #20 of 21 Old 11-02-2007 Thread Starter
Hitchin' a ride
bestfriend's Avatar
Not rum? (No offense taken.)
Vaya con Dios
Electrical System Upgrade... jswwrites Gear & Maintenance 0 09-15-2006 07:42 PM
Calculating Your Electrical Load Kevin Jeffrey Gear and Maintenance Articles 0 03-03-2003 07:00 PM
Electrical Power on Board Kevin Jeffrey Gear and Maintenance Articles 0 02-11-2003 07:00 PM
Electrical Power on Board Kevin Jeffrey Her Sailnet Articles 0 02-11-2003 07:00 PM
