Old 11-02-2007
gg30citation is on a distinguished road
Metal Plate
Hey All,
Can anyone give me a idea of what this mysterious metal plate on the side of the hull below the waterline is? It penatrates through the hull with electrical studs and terminals bolted to them on the inside. I just purchased a 30' Irwin Citation project and was curious as to what it was. It's approx. 3"W by 4"L. Thanks in advance for any help!
Old 11-02-2007
camaraderie's Avatar
moderate?
If you have an SSB radio or did at one time that is an SSB ground plate is my guess...usually made of sinctered bronze and called a dynaplate. Kinda looks like this?
Old 11-02-2007
ssb radio
Camaraderie
Thanks a million! with the pic you attached I'm almost 99.9% sure that's what it is. There is also an antenna mount at the top of the mast! If it's ok I'll take some pics tomorrow of what it looks so you can verify. Thanks again!
Old 11-02-2007
At 3" x 4", it is a bit small to be a lightning ground plate, since the recommendation for a lightning ground plate is to have at least four linear feet of edge.
Old 11-02-2007
pics
Mr. C,
Here is a pic of the plate..
Lightning Precautions Don Casey Gear and Maintenance Articles 0 08-09-2004 08:00 PM
Understanding Galvanic Corrosion Kevin Hughes Gear and Maintenance Articles 0 03-08-2004 07:00 PM
The Path to Lightning Protection Kathy Barron Seamanship Articles 0 08-13-2003 08:00 PM
The Path to Lightning Protection Kathy Barron Gear and Maintenance Articles 0 08-13-2003 08:00 PM
The Path to Lightning Protection Kathy Barron Cruising Articles 0 08-13-2003 08:00 PM
