11-05-2007
Nice job, Mr TB.
I get asked to do this kind of repair for people with mind numbing regularity...it is hard to see the best approach without taking a close look at the actuall specific problem...but here are a few methods I use...
For some deflections you can just heat shrink it back into shape. Steel always contracts more then it expands...so you can heat it a certain way with a torch and it will deform into the right shape as it cools...this is maybe not a game for the begginer. Heating stainless reuqires that you pickle it afterwards or it will indeed corrode. Fortunately this is easy to do with the new pickle gels...just paint them on and hose off 50 minutes later.
Whether using the comealong "pull" method or the jack "push" method, always consider where force is going and what might be deformed as a result. Big wooden blocks to spread the load are your friend!
In order to not flatten the tube, I have a range of router bits that give me a perfect half-round trench in the hardwood I put them though. I use the right sized bit for the size of tube I am working with. Cut the timber to the shape I want (The pster that mentioned springyness in stainless is right, if you want to bend to dead flat, it helps to go ever so slightly concave on the timber you are making the former from) and then run the router along the timber in order to make a "shape" that will not flatten the tube. I can then use a jack or clamp to apply force.
If I am working on pushpits or pullp its that are off the boat, I will use one fo those chipboard flooring sheets and bolt the thing down so as to have the mounting holes in the same place when I am finished as when I started. A sheet costs about $30 and I have used one sheet for about 10 projects, including welding...It sure beats swearing and cursing when stuff doesn't line up right when it comes time to put it all back together.
Sasha
