- Quick Menu
11-05-2007
Hello,
I had my 28' boat shrink wrapped over the winter for the last 3 years. The cost was about $350 for everything - they build the frame, shrink wrap the boat, install vents, and a door.
I was very, very happy with shrink wrapping. The vents allow plenty of ventilation and the boat stayed very dry. The white plastic even allowed enough light through for a solar battery charger, left sitting on the deck, to keep the batteries charged.
My new boat (35') came with a winter cover. It's 3 large pieces of canvas type stuff. My boat is now out of the water  and in the yard. When I finish a few winterization tasks I'm going to try and cover the boat. The cover was made for mast up storage, and my mast is off the boat, so it will be interesting to see if I can make the cover work. If not. I will call the shrink wrap place right away.
In the yard I use, it's about 50 / 50 between shrink wrapped and tarps / over covers. I can tell you that at least 50% of the tarps, etc. don't make it through the winter. If you go down to the yard after a big storm, you will see lots of covers blowing around, doing a significant amount of damage. Last year I thought one guy was constructing a building around his boat! First good storm and it looked like the big bad wolf huffed and puffed and blew down his stick building. I have never seen a shrink wrapped boat have problems.
Anyway, it's up to you, if you cover it yourself, be careful in how you tie it down - don't go to the boat stands, don't let the cover chafe on the hull, don't let the frame fall down, etc.
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
11-05-2007
I have tried both methods, and IMHO you either need to devote too much money or lots of labor/time to get a tarp/frame that is better than shrink wrap. As noted elsewhere in this thread, a custom canvas tarp is going to cost thousands; even more if you want them to build you a reusable frame too. Of course you don't need to pay this kind of money. You can build a nice frame yourself and cover it with cheaper tarps that will last a season or three.
I copied an idea I saw somewhere on the web on building a PVC pipe frame for my boat. Covered it with a hardware store tarp myself. Total time spent: about 8 hours. Total cost for materials: about $75. It lasted about a week before the PVC frame broke. I spent another few hours fixing that first break with wood and duct tape. It broke again and again. I finally gave up trying to fix it. The mangled mess still kept most of the snow off her. I realized that I would need a much stronger frame. I designed one, only to realize that I really didn't have the time to make it. It would have taken me probably two whole days (most likely a skilled carpenter could have knocked it off in a few hours). I just don't have that kind of time to devote to the boat. So, every year now I pony up a few hundred bucks to have my boat shrinkwrapped. I don't have the moisture/condensation problems that others here have described. Vents and well-placed openings around the stern pulpit keep air moving. I don't like the expense, but my alternatives are to buy a cover that cost more than the boat, or devote time that I don't have. Not much of a choice.
11-05-2007
Barry,
The Fairclough 'mast up' covers have very good cinching turtlenecks at the mast and the shroud exits. I have stored with the mast down when I had mine and simply cinched up those turtlenecks and only got a few drops of water in.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
11-05-2007
One caveat that hasn't been mentioned here yet. If your boat is painted, especially with Awlgrip— DO NOT LET THE SHRINK WRAP TOUCH THE PAINTED SURFACE FOR ANY EXTENDED PERIOD OF TIME. If the shrink wrap remains in contact with the painted surface, there's a really good chance you'll get some nice bubbling of the paint.
11-05-2007
I'd rather be sailing
I forgot to mention - I would be using the inexpensive $100-$200 type of synthetic tarp - not the multi-thousand custom tarp. We've already built a great frame - 1" electrical conduit and a pipe bender worked wonderfully. Since we'll be selling the boat next year, we don't want to invest in a custom cover - we will never get our money back for it. My concern about the inexpensive tarps was their potential abrasiveness against parts of the boat as the wind comes up and under and shakes the tarp. There is no way to stop this from happening. I felt shrink wrap would not do the same thing.
SD - I have no idea if my hull is painted. If it was, then it was many many years ago. I'm assuming it's just gelcoat.
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. "Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
11-05-2007
West marine tarps?
I am keeping my Ches. Bay sailboat in the water this year. I bought 2 10 by 15 tarps from West Marine.
We don't get much snow, so my idea is to put these over the boat and tie to the rub rail which is metal and easy to tie to.
I am trying to keep the teak somewhat protected, and the boat dryer.
They seem a bit like heavy reinforced plastic, silver in color.
If they don't last through a heavy blow I am only out $25 apiece.
I am wondering if I am seriously doomed for failure, and if anyone else has used these inexpensive tarps.
Thanks, SaltyPat
11-05-2007
The inexpensive tarps I used last year where bought from Harbor Freight. They were on sale and very cheap. I bought 3 times the amount that I needed. I may have spent as little as $5.00 each. I used last years tarp to wrap my mast. Fresh tarps bought last year will be used on the boat, this year. I tie them down around the bottom of the boat and not to the rub rail.
S/V Scheherazade
I had a dream, I was sailing, I was happy, I was even smiling. Then I looked down and saw that I was on a multi-hull and woke up suddenly in a cold sweat. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
11-05-2007
Arf!
Originally Posted by SEMIJim
We purchased a heavy-duty tarp from Harbor Freight and we're going to build a frame out of 6" dia. PVC (for the spine) and the heavier-duty sprinkler system pipe tie-wrapped to the stanchions. The advantage to the sprinkler system pipe is it's pre-curved. Saw two other boats doing this yesterday. If you put the spine up high enough, you can get the sprinkler pipe to curve right to the top of the stanchions, thus eliminating them as a trouble spot or having to remove them. Also: If you build the thing high enough, you can work in there in the winter. Or just hang out  .
I haven't decided what I'm going to use to elevate the spine. It seems everybody else uses wood. I'm wondering if using the same PVC as the spine, or maybe 4" dia., slotted into the spine with T-fittings, and with the bases also formed of 4" PVC with T-fittings, might not work better? The only thing is the potential added expense.
Jim
I did this for a couple of seasons, but have given it up for a [better] method. What I did not like about the heavy sprinkler tubing is that the pieces you need to span an 8.5' beam are really unwieldy to transport from the boatyard to the house. Also the only way I could fix them to the stanchions was to slide them over. Convenient? Not really, because I had to take down my lifelines  But if you are going to follow this method, it is much easier to get the curvature you want after pouring some hot water into the black tubing to soften it.
My current method involves PVC plumbing tubing. I think it is 3/4 in. I cable tie these to the inside face of the stanchions, then join them into a hoop by overlapping and cable tying and using duct tape to reduce wear on the tarp. The spine is made from lengths of 2" PVC joined together with PVC couplings and screwed together. It is inside the hoops and connected to them by duct tape. It is there only to keep the hoops from moving, not to support any weight. The spine is supported by the bow pulpit and 2 wooden fixtures with carpeting underneath to protect the deck.
The advantage of either method is that the tarp is forced into a convex shape so that it does not form pockets to collect snow or water.
Finally, to hold the whole thing together, I use tarp grabbers (not the grommets) to gather in several thicknesses of tarp, joined under the hull using bungees and rope. Each connection has one bungee even though there may be some rope at either end. This is more effective than trying to tie it up tight or using antifreeze gallon jugs or ... It works well because when a gust of wind hits the tarp the bungees yield a bit, relieving the stress that would have ripped out the grommet or tarp grabber. Last year I did not have to retie anything. For me that was a first.
11-05-2007
Aquaholic
Thanks Jim, That's what I was pretty much gonna say.
I think that the average job of shrink-wrapping may do more harm than good.
A well done tarp arrangement can be a lot better than a poor wrapping job; and visa-versa.
I don't know about other places, but there was a big push in DownEast Maine a few years ago to sell the shrink-wrapping equipment as a quick money/low investment scheme; therefore there are a LOT of low skill shoddy/workmanship "wrappers" around.
I suspect what Ajari was suggesting was the difference between vented and un-vented coverings, not covering vs. no covering.
Jim
TB, I wasn't suggesting leaving a boat un-covered, though I may have been rather unclear about that. I was suggesting wha tI just explained above; but was rushed. I should never post in a hurry................
I got an Old Fat Boat
She's Slow But Handsome
Hard In The Chine, but Soft In The Transom
I Love Her Well, And She Must Love Me
But I think It's Only For My Money
. ..... Gordon Bok
11-05-2007
You also want to make sure the overlap point is well secured so that snow/wind/ice/rain doesn't find it way through there.
Prevailing winds play a role here. I have my tarp opening like a tent flap tied at the aft end of the boat, and I frequently tried to have my stern pointed south or south east, as this is the least likely direction locally from which freezing rain/snow/blizzard will arrive. Also having the boat pointing into the prevailing winds makes chafe less of an issue.
| Thread Tools |
Search this Thread |
