11-05-2007
A 1966 Cheoy Lee is going to require a lot more than simply refinishing the "topsides" and varnishing, unless it has been impecably maintained...which doesn't seem likely from your brief description. And, if by "topsides" you actually mean the hull above the waterline (correct usage), what then about the decks? Teak? Fiberglass? Leaks? Cheoy Leaky built in lots of "gotchas".
My guess is that once you investigate you'll find LOTS of things which need doing quite apart from the hull and varnishing. I'd put it wherever you can, put a covering over it, and work on non-beautifying projects over the winter. Shrink wrap might be good, 'cuz it's easily available and allows you to work inside the boat in wintertime, with a bit of heat aboard.
Tackle the varnishing and hull beautifying projects in the spring.
JMHO,
Bill
