Old 11-05-2007
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
Backstay replacement.
Where can I find a place to make me another cable? Do they have premade backstay cables that I can order even if my boat is no longer made? From what I've been finding (or not finding) it looks like I'll have to get one made.
Merit 25 # 764 "Audrey"
Old 11-05-2007
ZZ
I assume your back stay is metal wire, correct?
You can make one out of Dyneema rope, will do the same thing, be lighter, stronger and easier to fabricate. If you can't splice it (that's the hard part) , you can allways tie a bowline to it.
However, need more details, what boat, how you adjust etc.
Your question was like....help I had a flat tire, where can I get a new one???
Old 11-05-2007
ZZ-
Call up Rigging Only in Fairhaven, Massachusetts, and ask them. They can make up a backstay and ship it out to you...and have pretty good prices and excellent service.
Of course, as Giu has pointed out...it would help if you said what boat you need a backstay for...and if you have the length of the backstay (eye-to-eye) and the diameter and material specification of the wire and clevis pins used currently.
Old 11-05-2007
JimsCAL's Avatar
JimsCAL is on a distinguished road
Any local rigger can make one up for you. As stated, he will need diameter and pin-to-pin dimensions. Far easier to do the measurements and replacement if the mast is down!
Old 11-05-2007
SailorMitch's Avatar
Senior Moment
SailorMitch will become famous soon enough
Most West Marine stores have the wire, swages and equipment you need to make your own stays. Or you can use Norseman or Hayn Hi-Mod fittings (I have some experience helping a friend with the Hayn and can recommend that as being pretty easy to install.)
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
Old 11-05-2007
Hayn Hi-Mod are a bit nicer than the Norseman or Sta-Locks, since they have a crown ring that helps keep the wire strands in the proper positions.
Old 11-06-2007
zz4gta's Avatar
Sorry about that, Its a Merit 25. Yes it is a metal cable, and it splits at the lower end aprox. 3 feet from where it attaches at the transome. The lower ones (after the split) are fine. But the single stay running to the mast head has a kink in it from improper storage. Thanks for the advice!
SSB Un Insulated Backstay ranes Gear & Maintenance 13 10-11-2009 09:14 PM
non-insulated backstay HF antenna for metal boat jimthom Cruising & Liveaboard Forum 0 05-31-2007 04:54 AM
running backstay bkw Racing 8 12-09-2006 04:34 PM
Adjusting the Backstay Dan Dickison Seamanship Articles 0 08-07-2002 08:00 PM
