11-06-2007
I have two of them installed on my boat. One is setup just aft of the mast and exhausts air from the boat, the other is right by the companionway, and acts to pull air into the boat. The cabin temperature has dropped considerably—at least 15–20˚cooler on a hot summer day.
They make them in two very different designs... one uses a plastic snap-in deck plate, the other uses a stainless steel screw-in deckplate to hold the ventilator, and comes with a bronze deck plate to close off the opening when the vent is removed. If you plan on sailing in heavy weather at all, you'd be wise to get the latter, not the former. BTW, I have the latter kind.
That said, the do keep the cabin relatively dry against spray, rain and other such...but wouldn't in the case of green water sweeping the deck.
