Blogs
User Name
Old 11-06-2007
dhornsey dhornsey is offline
dhornsey is on a distinguished road
Cold Weather, No Glow plugs
Just wondering if anyone has any advice for heating up an engine block that has no glow plugs. When we're at the dock I can aim an electric space heater at it for a few minutes and it starts like a charm.
Any suggestions for a solution away from the dock?
A torch? (seems risky)
Heat packs? (not hot enough?)
Thanks!
Old 11-06-2007
erps's Avatar
erps erps is online now
Puddin' head
erps will become famous soon enough
Never thought about using an alternative heat source to warm the engine. I just crank it a little longer when it's cold.
Although I've not tried it, I recollect some advice at one time to crank the engine for ten seconds or so with the fuel shut off cable pulled. The compression alone will start to warm the cylinders and then release the fuel shut off to start it up.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
http://www.youtube.com/watch?v=r5EWSEP-JA8
"Everybody has to be somewhere, sometime."
Old 11-06-2007
Faster Faster is online now
Just another sailor
Faster will become famous soon enoughFaster will become famous soon enough
We used a 250 W heater element (just a flat metal element, didn't get hot enough to glow, but warm enough to surprise you if you touched it) in our engine box. It kept the whole area fairly toasty all winter long, and really helped with winter cranking, mostly by keeping the oil warm. We used these heaters at work to keep instrument housings from freezing.
Of course they only worked with shore power... On the hook you're kind of stuck... run the engine frequently enough to prevent it getting stone cold.
Sponsored Ad
Old 11-06-2007
haffiman37 haffiman37 is offline
haffiman37 is on a distinguished road
Which engine?
Old 11-06-2007
captainjay captainjay is offline
Reforming Stinkpotter
captainjay is on a distinguished road
As long as you watched your battery reserves or had a genset, this should work.
http://www.padheaters.com/applications.html
Jay
Old 11-06-2007
Jay
Most diesels might be equipped with heating elements (glow plugs) in the intake manifold to heat the inntake air which is what You need. Heating block or oil-pan is a waste of energy unless You are starting in -40C!!!!
Some engine manufacturers have kits, some not. but as said above, I need Your make and model.
Old 11-06-2007
witzgall witzgall is offline
witzgall is on a distinguished road
Add glow plugs?
Can glow plugs be added to a Volvo 2002?
Chris
Old 11-06-2007
blt2ski blt2ski is offline
Another option, altho not eh best, is to try either or some other preferably less volitale agent, like WD40 to give the motor a bit of help is starting. Otherwise, for most temps around the NW US, SE Canada with low temps around 0-10F, heating aids should not be needed per say for diesel engines. They do and will rattle, be a bit rough initially, but they do get over it and go on there way. A lower wt oil will sometimes help on cold days too, but again, generally not needed around here. I run 15-40 in all 4 of my diesels, with out issues.
Marty
She drives me boat,
I drives me dinghy!
Old 11-06-2007
Chris
The only factory kit for Volvo I found was this:
http://accessorycatalogue.penta.volv...14&language=en
But there should be no problem doing the same on 2002, You just need plugs with less capacity.
Try this link:
http://www.iskra-agv.cz/us/aet_products.htm
Old 11-07-2007
Rockter Rockter is offline
Rockter is on a distinguished road
Only when the temperatures are very low indeed.
With good compression, you should not need them, really.
Display Modes
vB code is On
Cold Weather Clothing Bob Merrick Learning to Sail Articles 0 02-24-2004 08:00 PM
The Weather Triangle Michael Carr Seamanship Articles 0 08-17-2000 09:00 PM
How to Sail with Weather Bob Rice Seamanship Articles 0 04-21-1999 09:00 PM
Weather Forecasts for Sailors Michael Carr Seamanship Articles 0 08-31-1998 09:00 PM
Gathering and Using Weather Information Michael Carr Seamanship Articles 0 03-31-1997 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
