11-07-2007
Originally Posted by RXBOT
If 316 stainless is not ok with salt water all right we will get appropiate marine version. However I have some questions on the drag issue. I beleive a fairly compact unit will do the job. Now compare that to a !3 inch 3 blade prop?
Or what about towing a dinghy? In light air it might be a concern. On a displacement hull in strong wind or under power is that drag so important? Like a tugboat with a 50,000 hp engine its only going to make hull speed really no matter how far you push the throttle. Yet it could tow a huge payload at the tugs hull speed no problem.
Stainless underwater doesn’t do as well as bronze. The issue of drag is up to you. Some people don’t mind it and to others it is unacceptable to have more then is absolutely needed. To me a keel-cooler has too much drag but I am willing to use a narrow blade three blade propeller. Of course drag is cumulative and that is to say you have drag from the keel added to the drag from the shaft added to the propeller drag and now you add the keel-cooler which has significant drag on its own. It adds up and I think in this case it’s too much but this is in the realm of opinion and as they say your mileage may vary.
All the best,
Robert Gainer
Study the history of naval architecture and move forward knowing what didn’t work before.
Don’t waste time making the same old mistakes but instead make new ones and to insure your place in history be sure the mistakes are big ones.
Never design a mast that is weaker then the boat
Never design a boat that is weaker then the mast
Never listen to someone describe why your project will not work unless they can show you the broken pieces of their own version.
