11-10-2007
Hopfully this solves your problem
Originally Posted by TJC1010101
I bought this West marine oil change apparatus...It's a one gallon white plastic container with a pump..you attach the hose and it's extension which fits down the dipstick hole..
According to directions..pump about 8 times, and the oil then is supposed to siphon..
I'm pumping like a madman.. "US pumping team candidate" it draws up maybe half way and won't go any further..Some one suggested..run the engine to heat the oil...brought it up to 175..helped a bit bit no cigar..10-40 oil
I'm down in Mexico where resources of other apparatus is limited to none...gotta get this to work..any suggestions..
This is a 50 hr oil change on a new Yanmar 4HE Engine...First experience changing the oil...used this on a friends boat..on a Volvo worked just fine..
Hi,I'm Capt Thor,I hope I can help you with this problem,I have had similar in middle of nowhere> First of all,look at the end of pipe that goes down the dipstick hole,it is too be cut in an angle that steep,it never sucks to the bottom of the pan.Then next look for leaks on the container most likely by the pump.If you can get the plunger out of the pump cylinder inspect the o-ring or what ever it is tightened with.Might even be skin from leather,that can be renewed from pair of gloves>
Let me know how this winds on
All the best Capt Thor
