11-09-2007
Making an epoxy base is just a lot faster and simpler... since you can actually use the existing surface to mold the base. You can also use the base of the windlass to make the top portion of the epoxy base, leaving it a very strong custom fit. This is especially true if the surface in question has compound curves, which are very difficult to work into a wooden base.
Also, a properly made epoxy-fiberglass base is going to be far lower maintenance than a teak base would be over the years. Personally, I'm more interested in sailing my boat, than varishing the wood work on it.
