Volvo Penta Running Rich - Page 3 - SailNet Community
post #21 of 33 Old 11-18-2007
Most of You seemes to be locked up in 'air volume'.
A diesel is calibrated in wheight units. If You go by mixture rate 15:1 it will mean 15 kg of air to 1 kg diesel at a given temp. The temp of diesel will normally not vary to much, usually similar to sea temp, but air temp and thereby density of air might be a different story.Not only the outside air temp but as much engine room temp is a big factor. Run on a cold day with engine room 'open' versus a hot day with engine room closed and the difference will be rather noticable.
The volume the engine sucks per stroke is 'constant' but the wheight of the volume sucked in varies a lot!
I keep out prop overload, dirty filters etc as they are not conciddered daily variables.
haffiman37 is offline
post #22 of 33 Old 11-18-2007
Another possibility for oil in the exhaust stream may be a faulty or stuck open water jacket thermostat, preventing the engine achieving the optimal operating temperature, resulting in incomplete combustion.
Ulladh is offline
post #23 of 33 Old 11-18-2007
Haffman...
It's breathing the same stuff... air.
Rockter is offline
post #24 of 33 Old 11-18-2007
Originally Posted by Rockter View Post
Haffman...
1 cubic air at 50C is lighter than 1 cubic air at 10C, this gives less oxygen/cubic. Engine runs rich. The engine sucks air in 'cubic' units/stroke, is injected with 'cubic units' of fuel, but variations due to temp makes a huge difference. No rocket sience, basic diesel knowledge.
post #25 of 33 Old 11-19-2007
Omatako's Avatar
"1 cubic air at 50C is lighter than 1 cubic air at 10C"
Just for my interest, how much lighter?
If thus was such a noticeable factor then trucking companies who use hundreds of thousands of gallons of diesel would have to modify their operating budgets from summer to winter. I have for many years worked for such companies where fuel is a MAJOR cost consideration and have never heard of such budget considerations.
Interesting concept . . . . . .
Andre
Omatako is offline
post #26 of 33 Old 11-19-2007
How much lighter depends, but why do 'hot air baloons' fly?
post #27 of 33 Old 11-19-2007
the pointy end is the bow
erps's Avatar
3, any exact same sized gas engine will use the same air volume as a Diesel as long as both are w/o a turbo or blower (naturally aspirated).
Not trying to beat a dead horse but just breaking it down a bit so I can understand it....
Take two mason jars, each the same size, and put the lids on them. Apply a vacuum of 20" on one of the jars. Which one has more air in it? (20" is the vacuum a gas motor pulls at idle) I don't think the restricted air intake on a gasoline motor can be discounted.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #28 of 33 Old 11-19-2007
Here is the relation...
P1*V1/T1 = P2*V2/T2
If the pressures are the same, it becomes...
V1/T1 = V2/T2
Make the volume ratio the subject...
V2/V1 = T2/T1
Since density (rho) and volume (V) are inversely proportional, you can write as...
rho1/rho2 = T2/T1
So, if the temperatures are 10 degC and 50 degC respectively, convert both to the absolute temperature scale (just add 273 to both) and write as...
rho1/rho2 = (50+273)/(10+273) = 323/283 = 1.1413
...or about 14 percent more dense.
The motor would rather breathe the denser air.
Rockter is offline
post #29 of 33 Old 11-19-2007
erps's Avatar
P1*V1/T1 = P2*V2/T2
V1/T1 = V2/T2
V2/V1 = T2/T1
Well...., yeah, when you put it that way...
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #30 of 33 Old 11-19-2007 Thread Starter
Thanks ERPS for your input. I think that you are right (blow back). I will see if I can capture some of the oil before kicking it back in for combustion.
As for the Diesel v. Gas air use, I think the answer is that a gas engine at full throttle uses that same amount of air as does an equivalent volume diesel (naturally aspirated in each case). However, the gas engine is using less when throttled back. Eg. you can adjust the air flow and then match gas flow as appropriate.
doffe is offline
Volvo Penta not buzzing stack Jeanneau 22 04-25-2016 05:52 AM
Volvo Penta Outboard? rhbroehl Gear & Maintenance 9 07-23-2011 01:40 PM
Volvo Penta Marine Diesel MD11C Parts Source? ntheyer General Discussion (sailing related) 35 04-07-2010 02:33 PM
Volvo Penta engine rondezvous Gear & Maintenance 1 09-24-2006 12:24 PM
Running Backstays Dan Dickison Gear and Maintenance Articles 0 05-14-2002 08:00 PM
