Volvo Penta Running Rich - Page 4 - SailNet Community
post #31 of 33 Old 11-20-2007
MacGyverRI's Avatar
Originally Posted by erps View Post
Not trying to beat a dead horse but just breaking it down a bit so I can understand it....
Take two mason jars, each the same size, and put the lids on them. Apply a vacuum of 20" on one of the jars. Which one has more air in it? (20" is the vacuum a gas motor pulls at idle) I don't think the restricted air intake on a gasoline motor can be discounted.
Gas engines use throttle plates to restrict the RPMS.
A Diesel uses the specific injector calibration (mm3) at a regulated fuel pump pressure which is limited by the governor to restrict the RPM's and that's why the Diesel intakes are big so there wont be a vacuum.
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points.
MacGyverRI is offline
post #32 of 33 Old 11-20-2007
MacGyverRI's Avatar
Originally Posted by Rockter View Post
So, if the temperatures are 10 degC and 50 degC respectively, convert both to the absolute temperature scale (just add 273 to both) and write as...
rho1/rho2 = (50+273)/(10+273) = 323/283 = 1.1413
...or about 14 percent more dense.
The motor would rather breathe the denser air.
On a typical boat gas engine w/ a computer, the computer would compensate via the O2 sensor and meter the injectors.
On a typical boat diesel w/ just a mechanical fuel pump, it would just run leaner w/ denser air. same fuel/more air = leaner.
Next,
Put the same diesel boat in a lake (if it exists) in Denver Co. and the lack of air density @ 1mi. above sea level and POOF! it will run richer. This is why older cars in higher elevations had to get the carbs. re-jetted smaller.
A gas engine boat w/ computer would run the same because the computer would compensate.
I'm still betting the OP just needs to really clean the injectors....
post #33 of 33 Old 11-20-2007
Take the engine covers off and tell us what happens. Does the black smoke reduce?
Rockter is offline
Volvo Penta not buzzing stack Jeanneau 22 04-25-2016 06:52 AM
Volvo Penta Outboard? rhbroehl Gear & Maintenance 9 07-23-2011 02:40 PM
Volvo Penta Marine Diesel MD11C Parts Source? ntheyer General Discussion (sailing related) 35 04-07-2010 03:33 PM
Volvo Penta engine rondezvous Gear & Maintenance 1 09-24-2006 01:24 PM
Running Backstays Dan Dickison Gear and Maintenance Articles 0 05-14-2002 09:00 PM
