11-12-2007
I don't discuss my member
Originally Posted by k1vsk
Just to clarify, only one model MaxProp can be EASILY re-pitched under water. Although it is possible to re-pitch the older ones too, the necessary partial disassembly is prone to create problems even if done expertly simply because people work better on dry land than under water. I'd be suspect of anyone that gives you the "no problem man" response.
No offense, but since you have never re-pitched a Max Prop underwater, you are unqualified to asses whether or not doing it that way is "prone to create problems." I have personally removed, installed and re-pitched many, many Max Props underwater with a 100% success rate. Is it a job for somebody unfamiliar with the procedure? Probably not. But PYI (the U.S. distributor for Max Prop) will unhesitatingly recommend qualified divers to Max Prop owners for underwater servicing of their products. The inference that in-water work on these props is a risky or shady undertaking is simply inaccurate.
"Clean bottoms are FastBottoms"
