11-12-2007
Major advantages of full batten mains are: - Greater sail area, since a fully battened main can have a greater roach
- Can often use slightly lighter cloth than would otherwise be possible due to having the battens—this is basically a wash most of the time since you have the additional weight of the battens
- Less flogging, since the battens help prevent the sail from flogging
- Easier flaking of the mainsail due to the battens, especially if used with lazyjacks
- Better sail shape in light air
- Better off the wind boat speed
- Less noisy
Some disadvantages of full batten mains are: - Slightly higher maintenance, since the batten pockets are often an area that requires repair
- Slightly higher cost to buy than battenless sails
