Old 11-12-2007
C & C 32'
fireman181 is on a distinguished road
Boom Yoke
I need to fasten a boom yoke for a boom vang. Purchased a stainless yoke, and need to fasten to boom, what fasteners are recomended, through bolt or machine screw??
Old 11-12-2007
C & C 32'
boom yoke
the boat is a C&C 32'
Old 11-12-2007
Are you talking about a boom bail??? If you are, you really should through bolt it and put a spacer over the bolt inside the boom to prevent the bolt from crushing the boom from overtightening... but that would generally require taking the boom off the boat, taking the gooseneck fitting off and then doing the installation, which is probably more work than you want.
Old 11-12-2007
max-on's Avatar
1997 Dehler 33
max-on will become famous soon enough
If you can, I would through-bolt with washers and lock-nuts versus machine screws, also use something like lanacote to isolate the stainless bolts / washers from the boom. Depending on where the loads are, you could also consider stainless rivets.
Old 11-12-2007
I'd second using TefGel or LanoCote to help prevent galvanic corrosion isues between the stainless steel and the aluminum.
Old 11-12-2007
C & C 32'
Thanks, bolt it is with coating.............
Deadly Serious about Booms John Rousmaniere Seamanship Articles 0 10-12-2004 08:00 PM
Control the Wicked Boom John Rousmaniere Learning to Sail Articles 0 05-06-1999 08:00 PM
