11-13-2007
I would replace the hoses and vented loops, since you don't know how old they are, and appearances can be very deceiving. Given how much work it probably was to tear everything apart to this state, do you really want to have to possibly do it all over again next season because you chose not to replace the hoses at this time.
I would recommend using SeaLand's OdorSafe hose for any of the larger sewage lines. Using a hair dryer, heat gun or boiling water will make disassembling the hoses much simpler.
