11-15-2007
Location: Dead Sea, some times called Long Island Sound
There could be a bad wire or connection between the switch and the starter or a bad switch. I had a bad key switch on mine, I had to play with it to make it work. Try installing a toggle switch in place of the starter button and see how that works.
Dennis
O'Day 302
Be careful or i will do what the voices tell me to do To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
To get the most from Sailnet, follow the link in To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 's signature. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Hey stuffit "Get a life"
