Link 2000 Battery Monitor - Page 3 - SailNet Community
Blogs
  #21 (permalink)
Old 11-17-2007
Valiente's Avatar
Valiente-
Might want to look at this battery monitor as well. A bit less expensive than the Link 20, and does two banks.
Nice tip. I thought I'd like the Xantrex unit because it can interface directly with Windows and I can monitor usage via Excel (amp draw of the fridge at 25 C in the saloon versus 33 C in the saloon might be useful information, as well as tracking stand-by versus active radar amp draws).
But this unit has its own attractive features, and manually transferring numbers isn't such a big deal, because once I know the draws of all the usual power-sucking devices, I can complete my energy budget.
  #22 (permalink)
Old 11-17-2007
Valiente's Avatar
Good ideas all around Valiente... I like the Duogen units... although there are better windgens...but none quite so versatile.
There are at least three makers of this type of unit, and I find it interesting that if you see wind as merely a supplemental source of power to solar, alternator and genset, you actually have the opportunity to tow such a unit at night in big air (when the drag would hardly matter), and its output jumps to number 2, right behind the alternator. 11-12 amps at 7 knots (easily achievable in the trades 24/7 in some situations) would alone exceed the normal night watch energy budget (fridge, a few LEDs, a radar on stand-by and the occasional GRIB download).
Add the sun in the daytime and you've got a lot of juice flowing.
I am fortunate in having bracketed steel plates designed to hold davits securely welded onto my transom. I could quite easily have a "tipping" pole trailing behind my stern, well clear of the windvane and the rudder. A small block and tackle on the arch would bring the thing upright again, and ready for wind service.
It's certainly something to think about, particularly as so many distance cruisers appear to be raving about it:
http://www.duogen.co.uk/custcom1.htm
  #23 (permalink)
Old 11-17-2007
Valiente-
Flip a coin... I'm actually planning on getting the Microlog unit and installing it next spring.
I'm trying to see if I can see a Duogen unit in person... I think Ferris here in Massachusetts might have one I can look at.
  #24 (permalink)
Old 11-17-2007
Valiente's Avatar
Originally Posted by HoffaLives View Post
It's really important to sit down and work out a power budget, and be scrupulous. There are small systems that are running and are easy to forget about, like a sniffer, a propane shut off solenoid, radio, and so forth. To be realistic you should list everything and to be safe double it, and you'll probably be closer to real consumption. And you likely are aware that these alternative power sources very rarely achieve anything close to their rated output. That's why it's important to have the best charging system you can afford.
And while redundancy is a very good idea, remember that reliability tends to suffer the more complex the system is.
I understand this, and thank you for the reminder. I adhere to the "triple/thirds" rule: triple the amp capacity you expect to use, based on only one-third maximum performance of one's gear.
The complexity thing may be an issue in terms of failure, but I'm hoping that buying quality...and quality spares...plus the ability to test and fix the larger sorts of circuits (wires, switches, solder jobs, etc.) will serve.
Due to a relative immunity to weight kept low, I'm able to have more battery capacity aboard than most, and this is the key to my evil plans: constant charging in one form or another to keep the whole battery system above 80%.
Note that while I've stated I don't care to run the alternator to charge the batteries, if I have to, I'll have to, and then I'll have to consider a built-in genset, or more solar/wind charging capacity. But we don't anticipate running A/C or electrical pressure/hot water or vast freezers or other big draws offshore. If this changes, I would have to rethink it. Right now, it looks as if even under marginal conditions, I will make more amps than I can use. Put me in high latitudes in winter, and this might change, but we plan on being for the most part between 40 N and 40 S.
Link battery monitor setup for AGM's PBzeer Gear & Maintenance 21 03-13-2007 09:54 PM
Battery Bank Design Kevin Jeffrey Gear and Maintenance Articles 0 05-12-2003 09:00 PM
Battery Bank Design Kevin Jeffrey Cruising Articles 0 05-12-2003 09:00 PM
Installing a New Battery Bank Sue & Larry Gear and Maintenance Articles 0 09-26-2002 09:00 PM
Boat Battery Power East Penn Manufr. Gear and Maintenance Articles 0 01-18-1999 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
