11-16-2007
I would highly recommend using a metal backing plate, preferably stainless steel, to spread the load of the ladder over a fairly large area of the transom. The forces on a swim ladder are pretty high. BTW, I'd second mounting it permanently as well as getting the most rungs you can. If the ladder doesn't extend far enough into the water, getting aboard using it is going to be very difficult.
Also, one that has standoffs, that keep the ladder rungs a few inches from the hull are better than ones that don't have standoffs. If the ladder is flush against the hull, it is very difficult to use.
BTW, most boats don't have quite as much freeboard as TB's..
