11-18-2007
The problem is that the magnetic field is proportional to the current IIRC... and if you're charging the battery, the current may cause a problem. That said, I doubt that it will be a problem, since it would take a fairly significant magnetic field to affect something 18" away. In any case, you really do need to test it to see if there is a problem or not, both under power and sail.
The battery itself shouldn't present a problem...it is just the cabling that may be an issue. Normally, you could twist the positive and ground wires to create some shielding effects, but that really doesn't work with battery cables since they're to thick to twist tightly enough to cause the shielding effect IMHO.
