Old 11-18-2007
tdw's Avatar
tdw tdw is online now
Super Fuzzy Moderator
Momentum - and a lack thereof.
Well that was fun.
So.....Sunday morning we get up, have breakfast, break out the sails and get ready to head out for a sail. Wonderful day, blowing 15-20, perfect weather for the Womboat. Cracking time was had by all but.....
When we sailed off the mooring I had the donk running and didn't need it. Coming home, I started her up to prepare for picking up the mooring buoy, slipped her into gear, engine revs, nowt else happens.
Resorted to the Code of the Wombats - "When in danger or in doubt run in circles scream and shout" - funnily enough it did no good.
Ok then have a quick squizz at the prop shaft , she is not doing the voodoo she should do so well, just sitting there as quiet as you like. Shine torch towards drive shaft to engine attachment point and hey hey it's spinning quite happily, merrily in fact. Sadly there are also four bolts hanging loose and a gap of some 50mm between engine and shaft. Oh dear.
Time for the great American screwdriver I'm afraid. Tappity tap tap until we were down to 10mm gap then replaced the bolts and pulled it tight with a spanner. All good, well except for a somewhat flustered Ms Wombat who was on deck wondering what the hell was going on with the banging.
Freaky at the time but I confess I've never checked those bolts. Perhaps I should have ?
What can go wrong will go wrong and at the most inconvenient moment. Toast, buttered and dropped will always land butter side down. Sod's Law and all that. Shite happens.
Old 11-18-2007
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
Glad it worked out. Of course, now you have to recheck your alignment. Had you removed the shaft recently? Seems strange that all four bolts would be loose, not to mention, if they had been working loose, you should have had some extra vibration when motoring.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 11-18-2007
Sapperwhite's Avatar
Not So Senior Member
Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about
TDW, I can't remember the name right now, but there are bolts with a hole in the head and you connect them together with siezing wire so they cannot back out without removing the wire. You lace all of the coupling bolts together and viola, no backing out. You might want to check into them.
Good recovery though, there are some that would have s#!t thier pants and called for a tow first.
Dictated, but not read.
Old 11-18-2007
bestfriend's Avatar
Hitchin' a ride
bestfriend is a jewel in the rough bestfriend is a jewel in the rough bestfriend is a jewel in the rough
A happy ending, and I love a good Blazing Saddles reference.
Great men always have too much sail up. - Christopher Buckley
Vaya con Dios
Old 11-18-2007
Are Wombats French??
Old 11-18-2007
cubacruising.net editor
pedrodelrio is on a distinguished road
Bolts backing out
Usually such mischief happens on new installations when nuts and bolts are shiny, new and coated with a thin layer of oil. Then as the oil falls off, moisture takes over and a thin layer of rust keeps motor bits from vibrating loose.
Old 11-18-2007
bestfriend's Avatar
Hitchin' a ride
Anyone use the non-permanent locktite, or does that not like salt water?
Vaya con Dios
Old 11-18-2007
fcsob is on a distinguished road
You can drill the head of the bolts for safety wire. Locktite work fine.I like red just use less. We bilt race motorcycles & that is all we used,had no problem on disasembly.
Old 11-18-2007
Owner, Green Bay Packers
sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice
Fluffy,
Would I be wrong to possibly assosciate this with the recent yard work done on the boat? I'm thinking all four, all at once, with no prior racket indicating looseness?-sounds fishy.
I also suspect you're downplaying just how busy the Wombat actually was in his burrow. I'll bet you were shitein' and gittin'. Very glad for a happy outcome.
Wm. F. Buckley, Jr.
Old 11-18-2007
Bermuda30's Avatar
On Blocks
Bermuda30 is on a distinguished road
as fcsob referenced, this is required at motorcycle track days and racing. Quick search turned up this: http://www.sportrider.com/tech/146_0002_hand/index.html
DeVos looks to regain his momentum (Detroit News) NewsReader News Feeds 0 09-28-2006 02:15 AM
Momentum Growing as Sailing Legends and Amateurs Prepare for 20th Annual Pro Am Regatta Week at Bitter End Yacht Club (Business Wire via Yahoo! Finance) NewsReader News Feeds 0 09-19-2006 03:15 PM
