Old 11-20-2007
maboyer's Avatar
Old New Boat Owner
maboyer is on a distinguished road
Sticky Tachometer
My new 1984 (8.6) S2's tachometer seems a bit 'sticky.' If I give it a little 'tap' with my finger it works.... It is the original control panel ( I think ). Any ideas?
This control panel has the 'id..t lights' plus the tach. I would like to install either a new tachometer or a complete panel of gauges.
All ideas appreciated.
Thank You,
Mike
(reposted from S2 forum)
Old 11-20-2007
capttb is on a distinguished road
On a gas engine the tach is driven by the coil, Most (?) boat diesels have a tach driven by alternator output (beats me how exactly) that can be a little touchy. Try cleaning the electrical connections for the tach., but if it works every time you tap it, you might be good. Lots of gauges are something to look at but other than temp. & tach. are usually the source of more worry than use on a diesel.
Old 11-20-2007
Valiente's Avatar
It is possible that your alternator belt is slipping due to improper tensioning, or is on the verge of fraying and thereby failing. My Westerbeke tach is driven by the alternator (so to speak), and I didn't realize the belt had failed until I motored to and from the pump-out dock with a "twitchy" tach that eventually went to zero.
Luckily, I also noticed the coolant temp was over 200 F. After I let the thing cool off (no damage done except to my nerves), I changed the belt. The old one had turned into five or six rubber bands. Always carry a spare belt!
Sticky Tachometer maboyer S2 3 11-20-2007 07:52 AM
Tachometer Calibration voyagersail Gear & Maintenance 3 03-22-2007 08:29 PM
tachometer retrofit for Yanmar YSM-12 Kabloona Gear & Maintenance 0 02-07-2007 02:50 PM
Tachometer not working?? bderosa Gear & Maintenance 4 08-02-2006 08:08 PM
diesel tachometer diesel MHRitter Gear & Maintenance 1 09-17-2002 11:52 AM
