- Quick Menu
11-20-2007
Bronze portlight install
Can someone tell me if or why I should use silcone bronze screws to throughbolt the portlights? Also, I want to use acorn nuts but cannot find any silicone bronze acorn nuts....should I use stainless nuts?
Thanks.....
11-20-2007
Aquaholic
Have you tried Hamilton Marine for the acorn nuts?
I would be inclined to use a similar metal for the nut, even though it's not submerged.
I love Bronze.
I got an Old Fat Boat
She's Slow But Handsome
Hard In The Chine, but Soft In The Transom
I Love Her Well, And She Must Love Me
But I think It's Only For My Money
. ..... Gordon Bok
11-20-2007
GBurton-
I would use silicon bronze screws, but you could probably get away with using stainless steel acorn nuts on the interior, especially if you use TefGel or LanOcote to prevent galvanic corrosion issues. The interior should be dry... so the real dangers of galvanic corrosion are minimal—unless you've done a really lousy job of installing the ports.
11-20-2007
Moderator
Thanks.....
GBurton,
What are the portlights frames made of? Aluminum, stainless, plastic, bronze, chromed bronze?
If bronze, I would stick with all silicone bronze hardware (nuts and bolts). If chromed-bronze, all stainless hardware would probably look better. There must be a source for s/b acorn nuts since we have them on our boat and I've often seen them on others. Hamilton MArine might have them, but my first look would be at Jamestown Distributors.
Edit: As for the interior of the portlights being dry, in theory yes. However, if you are installing solid bronze, through-bolted portlights, be aware that the interiors will "sweat" when there is enough interior/exterior temperature gradient. These portlights conduct both heat and cold, so in the winter will feel quite cold to the touch, leading humidity (from our breath and/or the propane stove) to condense on their surface.
11-20-2007
Good point JRP...  forgot about the condensation issues...
11-20-2007
Cheers John -
They are bronze. I have tried mightily to get bronze acorn nuts but cannot find them.
Originally Posted by JohnRPollard
GBurton,
11-21-2007
Yes, bronze, bronze and more bronze.
11-22-2007
Not So Senior Member
I have 10 bronze ports and they sweat like crazy in the winter when its nice and toasty down below and frigid outside. Sometimes they sweat so much they drip.
Dictated, but not read.
| Thread Tools |
Search this Thread |
