11-21-2007
Señor Member
EDIT- simultaneouly posted with halekai36.
Let me get this straight - you removed the teak rails for refinishing, reattached them to your deck without using any sealant, and you're surprised to find water intrusion to the cabin spaces below?
With all due respect, any penetrations through a boat - regardless of deck & hull composition, require some form of caulk, gasket or sealant. Otherwise, capillary action will cause water to travel through even the most minute spaces. Your best course of action will be to remove the rails and follow Simon's process.
To champher means to form an angled bevel to the screw hole's outer perimeter. As was said, this ensures that an adequate amount of sealant will remain around the penetration when the two parts are mated and compressed.
Your deck is most likely cored (not solid fiberglass), either with plywood, balsa, or a form of synthetic substrate material. If wood, the water of course will eventually rot the deck's core - evidenced by a spongy deck.
To prevent this, ream out the perimeter of each hole and fill with an epoxy, such as the West System, prior to caulking and reattaching the rail components.
True Blue . . .
sold the Nauticat
