Blogs
User Name
Old 1 Week Ago
badsanta badsanta is offline
IslandPacket31
badsanta is on a distinguished road
nav light question
I am trying to save some electrical breaker space. I bought a small navigation panel with 4 switches to control the nav lights. Now with this new switch I have some questions,
the panel has 4 switches
Running
Mast head
steaming
anchor light
mast head- would be my tricolor sailing light
Anchor-is the anchor light
What is the differance between Running and steaming lights??
What am I missing, or am I thinking to much?
I know you all will set me right. Many thanks Al
Old 1 Week Ago
T37Chef's Avatar
T37Chef T37Chef is offline
Senior Culinary Member
T37Chef will become famous soon enough
Steaming light is used when the engine is in use, no matter if sails are up or not. In combination with the running lights, bow & stern it will provide a 360 white light.
Alone, the running lights wouldn't provide the white light 360 degrees needed while under engine power.
1982 Tartan 37C #358
Old 1 Week Ago
funsailthekeys funsailthekeys is offline
funsailthekeys is on a distinguished road
hope this helps
USCG rule 25 depending on the length of your vessel you can use a tricolor at the top of the mast for running while you are under sail, if you use the engine under sail you must display a steaming light or another name is mast head light. The mast head light is displayed 225degrees in the front of the mast near the midsection of the mast. The anchor light is displayed 360 degrees at the top of the mast for when you are at anchor. For a better picture page 454 in the West Marine catalog will show this.
Old 1 Week Ago
IslandPacket31
I am still confused, Sorry.
So under power I am to display a 360 light?? what about the mast and stern light??
I may be wrong, but from my understanding, the tri color is for sailing. If under engine power I would then use my Bow lights along with my forward mast and stern white light.
Running- would be just bow and stern light???
Mast head- is for sailing (tri color)?
steaming- is for under power, Bow, stern and mast light?
anchor light- is for at anchor
I am trying to get this right. Many thanks Al
Old 1 Week Ago
IslandPacket31
So as I under stand what you are saying. I would wire the switch as follows.
Running--- to the bow, port starbord light
Mast head-----to the mast tricolor light
steaming------to the light displayed 225degrees in the front of the mast near the midsection of the mast and the stern light.
anchor light ----- to the anchor 360 light
Am I getting close yet??? Thanks again Al
Old 1 Week Ago
T37Chef's Avatar
No, the stern white light should be wired with the bow green/red light. The steaming light independent as well as the masthead tri color.
Old 1 Week Ago
IslandPacket31
Thanks T37Chef, That makes more sense. Thanks for the quick answers Al
Old 1 Week Ago
sailortjk1's Avatar
sailortjk1 sailortjk1 is offline
sailortjk1 will become famous soon enoughsailortjk1 will become famous soon enough
I will deleate mine than.
There is one good rule in helmsmanship-let the boat do the sailing.- Peter Heaton
Old 1 Week Ago
hellosailor's Avatar
hellosailor hellosailor is offline
hellosailor will become famous soon enough
Santa-
Navigation Rules Online
COLREGS online, free, from the USCG.
Rule 25a requires you to have sidelights AND A STERN LIGHT and those three would all be hooked up as "running lights". Whether the side lights and stren light are low down, or combined in a masthead tri, is up to you. But all three lights would be "the running lights".
That might or might not be the "masthead light", remember that panel is an attempt at "one size fits all" and many panels get relabelled.
You might use the anchor and steaming lights as they are labelled, and if you have a fourth lighting switch unused, many of us use it for a downlight (deck light) that is part of a combination steaming light/deck light mounted in one fixture on the front of the mast.
Old 1 Week Ago
IslandPacket31
I will do that, I think I was having trouble with the terminology.
Sailortjk1 no need to remove, I just hadnot responded yet, but your response was helpfull to me, But I was still confused. But thanks for your help. Al
Display Modes
vB code is On
Forward Nav Light Wiring craigtoo Gear & Maintenance 21 02-22-2008 06:39 PM
Nav Station Design Mithril Gear & Maintenance 21 07-03-2007 06:30 PM
Setting Up Your Nav Station Sue & Larry Gear and Maintenance Articles 0 07-26-2002 08:00 PM
The Power of Light Air Doran Cushing Racing Articles 0 01-18-2000 07:00 PM
The Joy of Night Sailing Sue & Larry Cruising Articles 0 05-31-1999 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
