Old 11-22-2007
Quickstep192 is on a distinguished road
Removing barnacles from outdrive
The lower unit of the outboard on my Quickstep is in the water constantly. This year, it got crusted with barnacles. I scraped the barnacles off while it was still wet, but each of the barnacles left a thin adhesive like circle behind that is completely resistant to a wire brush. Is there a trick to getting this stuff off?
It's a small motor, so it would be easy to dunk it in a bucket for a while.
Old 11-22-2007
I believe that vinegar will get the circles off... You might want to get some antifouling paint for your outboard. The stuff they use on stern drives and outdrives should work, since they're basically fairly similar in construction.
Old 11-22-2007
Dog, That's the really bad part. It had antifouling paint. Unless something new has come along, outdrive anti-fouling doesn't last long.
Barnacles Alden68 Gear & Maintenance 6 05-21-2007 09:47 PM
barnacles affecting steering sgaterboy General Discussion (sailing related) 11 12-12-2006 09:40 AM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Removing Thru-Hull Fittings Dan Dickison Gear and Maintenance Articles 0 04-23-2002 08:00 PM
Removing Old Names Tom Wood Buying a Boat Articles 0 11-05-2000 07:00 PM
