11-23-2007
It may have to do with the phone type as well, I was using B-terms and Mini-M terminals...not a hand-held, and back then it was a legal requirement. I had a sat phone with a 3'x3' antenna setup in my living room for several months.
Originally Posted by camaraderie
Dawg...I thinkthat info on the continental USA is badly out of date. Globalstar for an example, has an entire set of rate plans based on making calls from USA Home Territory which is defined as 48 states, Alaska and PORTIONS of the Caribe. They wouldn't have this if using your phone in the states was illegal.
As for the air cards...it depends on both the carrier and the card. Also, many of the carriers were just rolling out their high-speed networks (2.5G and 3G) a few years ago, and the situation has changed fairly dramatically in the last three years...
On the "air card" issue...it really varies by location which company has the be coastal coverage since PHONE CALL coverage and DIGITAL NETWORK coverage can be widely different. One company may provide significantly better coverage in specific coastal areas than others. Based on reports I've read...it seems like for EAST COAST best coverage right now, Verizon has the most air card coverage.
