Old 11-26-2007
wildlawnc is on a distinguished road
Gelcoat nicks on bow
Have a catalina 25 with quite a few gelcoat nicks on the bow--looks like PO didin't do great job of tying her up and bumped the dock some? No moisture on interior, don't appear anything other than superficial, but go from just above waterline to near the trailering hook. Any advice on repair, any experience with this type of situation, using some sort of protective covering, etc? thanks.
Old 11-26-2007
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
If you're not too concerned with perfectly matching the white gelcoat, consider using Marine-Tex to slightly overfill the nicks. When set, shave the surface flush with a single-edge razor, sand with 400 grit - preferably finer, apply/buff a HD fiberglass rubbing compound, polish, then wax.
Otherwise, there are several gel-coat repair kits on the market, with color matching tints.
True Blue . . .
sold the Nauticat
Old 11-26-2007
Try and get the Marine-Tex as close to fair as possible. The stuff sets like concrete.
Old 11-26-2007
hellosailor's Avatar
I'd also go with the MarineTex, it is a no-fuss permanent solution. Then, if you are worried about the bow, add some type of strike plate (i.e. brass or stainless strips welded together to cap over the edge) or other cosmetic trim to cover it up.
Get new sailcovers and sail ties, gussy up the boat, no one will stare at the sharp edge for long.
Modern Hull forms and Motion Comfort Jeff_H Sailboat Design and Construction 34 04-13-2012 01:41 PM
Fill that hole GoodOldBoat Gear and Maintenance Articles 0 07-23-2007 09:54 AM
Repairing Gelcoat Cracks and Chips Don Casey Gear and Maintenance Articles 0 11-06-2002 07:00 PM
Recovering the Shine Don Casey Gear and Maintenance Articles 0 08-04-2002 08:00 PM
The Basics of Doing the Bow Rich Bowen Racing Articles 0 03-20-2002 07:00 PM
