11-26-2007
I have the seawater inlet and the sink drain plumbed into the same vertical, with a T to the head. The T is slightly below the waterline.
To drain the sink, I open the seacock, close the T-fitting to the head, and pull the sink plug. Bye-bye...
To winterize (I haul out, but this would work in the water as well), I close the seacock, open the T-fitting, pour pink stuff in the sink, and pump the head (the holding tank has been pumped out at this point.) The sink is higher than the head, and WANTS to fill the head with every stroke.
After I'm convinced the hoses have pink stuff all the way to the holding tank, I pour a cup into the bowl itself, splash a cup or two into the bilges (in case water gets aboard by some fashion and then freezes...) and that part is done.
