Portable Generator vs Genset - Page 2 - SailNet Community
post #11 of 110 Old 11-27-2007
I always wonder how the danger(s) posed by gas gensets such as the Honda compare with that of propane which is almost ubiquitous to cruising sailboats. Regardless of one's use of a gas genset, gasoline is typically already aboard most boats for use in the outboard which leads me to believe the gasoline hazard posed specifically by gensets is moot. Certainly the availability and use of propane sniffers is comparable to that of CO detectors so availability of warning devices is also a moot issue.
Intuitively, I would think that propane causes far more accidents than gasoline and as both are commonly found aboard (gas for outboards and propane for cooking).
Do the statisitcs bear out the warnings against the use of gas gensets?
Paranthetically,I was parked immediately behind a boat using a Honda sitting on his transom last summer in Cuttyhunk and tried paying attention to it's use as I was considering buying one at the time. Not having heard it running all day , I vertured over by dinghy that night to ask only to hear it was in fact running - convinced me about it's quiet operation.
k1vsk is offline
post #12 of 110 Old 11-27-2007
Moderator
JohnRPollard's Avatar
Propane accidents are rare - especially when you consider how many boats are so-equipped. Carbon monoxide poisoning occurs frequently. There have been so many cases of carbn monoxide poisoning, including many deaths, that the Coast Guard in recent years has stepped-up it's campaign of warning boaters about the risk. Carbon monoxide can "pool" in unpredictable locations -- so fitting your boat with a CO detector(s) may or may not help you.
The big difference between the risks of propane and CO from gasoline combustion is that the propane appliance, when functioning properly, is not a risk. The gasoline appliance, when functioning properly, is emmiting a poisonous gas.
JohnRPollard is offline
post #13 of 110 Old 11-27-2007
John—
That's kind of a given, and every boat that runs a genset should have a CO detector aboard.
sailingdog is offline
post #14 of 110 Old 11-27-2007
Seńor Member
TrueBlue's Avatar
Originally Posted by JohnRPollard View Post
Folks are probably tired of hearing me say this, but I'm going to repeat myself nonetheless:
The U.S. Coast Guard and ABYC recommend strongly against using portable gasoline generators aboard recreational vessels. Carbon monoxide poisoning is the greatest threat, as is risk of fire.
Please don't anchor ANYWHERE near other boats if you plan to use one of these on deck. Nothing ruins a peaceful anchorage quite like an air-cooled portable genset.
I could not have said it any better than John.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #15 of 110 Old 11-27-2007
CGMojo's Avatar
Good Info
Great information as usual, thanks!
CGMojo is offline
post #16 of 110 Old 11-27-2007
Moderator
John—
Agreed, but Diesel gensets do not pose the same risk.
post #17 of 110 Old 11-27-2007
John-
While diesel gensets don't pose the same fire risk, they do provide a serious CO risk.
post #18 of 110 Old 11-27-2007
TAK
TAK's Avatar
How much quieter do you think the diesel Genset will be - particularly to the people on board?
A friend has a Honda on his boat using it forthe coffee maker and charging batteries .. I kinda liked the idea of using to it to run a portable ac heater briefly in the morning to take the chill out of the boat during the late fall or early spring anchorages..
s/v Mahalo
Caliber #4065
ACM - Eastport MD
TAK is offline
post #19 of 110 Old 11-27-2007
All good points of view but for those of us who also have a gas genset sitting in the garage or shed, it's not a big deal to ensure it is stored and run safely since we're used to it. From what I've observed, the objectional noise from this particular genset sounds (pun intended) like a perceived rather than real concern.
k1vsk is offline
post #20 of 110 Old 11-27-2007
BTW, diesel gensets are generally noisier than gas gensets of the same size. The two-stroke gas gensets are pretty noisy, but the four-stroke Hondas are pretty quiet.
portable anchor light ktwessling Gear & Maintenance 15 08-27-2006 10:51 AM
Genset information needed drwill Gear & Maintenance 0 06-03-2005 07:29 AM
Portable Air Conditioners SailinJay Gear & Maintenance 4 07-22-2004 04:54 PM
The New Sailrite Portable Sewing Machine Tom Wood Gear and Maintenance Articles 0 11-18-1999 07:00 PM
The New Sailrite Portable Sewing Machine Tom Wood Cruising Articles 0 11-18-1999 07:00 PM
