11-27-2007
Senior Moment
Wind Instrument
You advise that you have 12v at the instument head. Does it power up and not show the data? Usually the wiring coming from the sending unit, the annenomoter and the vane are plugged into or connected to a block or is it plugged or wired to the rear of the unit? I'd check my connections prior to ascending the mast. In your manual, if you have it, does it show that the unit "plugs" into the wiring going down the mast or is it factory wired at the masthead. If factory wired, more than likely your problems are below than above. As both transducers are not transmitting, ie direction and speed, it would reinforce my opinion that the problem sounds like a connection. Check your manual and good luck. Hope this was some help.
Mike and Joyce, S/Y "Tattoo"
"There is nothing- absolutely nothing-
half so much worth doing
as simply messing about in boats."
The Wind in the Willows
