Westerbeke or Yanmar?? - Page 3 - SailNet Community
post #21 of 37 Old 12-06-2007
CBinRI's Avatar
I found my Yanmar to be extremely reliable and to require very little maintenance.
CBinRI is offline
post #22 of 37 Old 12-06-2007
christyleigh's Avatar
Another vote for Yanmar. I had a Westerbeke 18 with a glow plug problem brand new (fixed easily) for 3 years. Next a Yanmar 3GM30 new for 6 years (in a c320) that I liked except for the fact that I had to unbolt and move the coolant pump out of the way to access the raw water impellor - don't know if the 3YM30's that they are now putting in the c320's have the same impellor access issue. Now I'm a couple years into a 8 year old Yanmar 4JH2 that runs perfectly and starts in the spring after winter layup as if it was just shut off.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
christyleigh is offline
post #23 of 37 Old 12-06-2007
HoffaLives's Avatar
Originally Posted by sapo View Post
anyone have experience with the marine-ized (marinated?) volkswagon diesels? seems like they might be good for getting non-marine parts.
this might be a little out there, but vw's venerable aircooled fuel injected two litre might work well in a boat. they take up very little space, are torquey as hell, don't need a raw water cooling system, parts are as cheap as it comes and you can get them anywhere. you'd have to provide some ductwork for air exchange, but you sure would have a one of a kind auxiliary
red peril
severodvinsk class russian submarine
1993
364 feet
our life afloat:
HoffaLives is offline
post #24 of 37 Old 12-06-2007
CaptainForce's Avatar
We cruised for for 15 years with a Westerbeke 4-107 and for the last 8 years with a Yanmar 4JH4E. Both engines served me well, but my choice would be the Yanmar by performance, maintenance and cost. 'take care and joy, Aythya crew
CaptainForce is offline
post #25 of 37 Old 12-19-2007
Westerbeke
In my opinion I would go for the westerbeke. This is a Mitsubishi based engine. The K3D if I'm correct. For years I'm working with these engines as a mechanic and it happens to be a very reliable engine. The yanmar engines are also reliable but a bit more expensive as it comes to spareparts. And after a few years they always seems to have a bit more problems than the mitsubishi based engines.
The mitsubishi block is worldwide used by a lot of agriculture and industrial products so spareparts are widely available.
The mitsubishi block is also available by other brands. Such as Solé Diesel (Spanish) and Vetus (Dutch). I don't know how the prices are in the US, but in Europe they are a lot cheaper then Westerbeke.
bucho is offline
post #26 of 37 Old 12-19-2007
Living & Cruising on Dana
I think you should first look at where the engine will be placed. Most engines have different spec's and they have to be properly supported if you don't want problems in the future. So measure up the distances between the engine mounts, and then, if possible, find an engine to suit the existing dimensions, that will be a lot cheaper than trying to do it the other way around.
Your pleasure is my business !!!
________________________
Robby Barlow is offline
post #27 of 37 Old 12-19-2007
chef2sail's Avatar
Yanmar would be my choice. We have the predecessor to the engine you are looking for 25 year old 3GM30. Runs line a charm with over 4000 hrs.
Footprint is usally smaller than the Westy and lighter. My second choice if I wasnt going with the Yanmar would be the Westy> Engines are usually only as reliable as you maintain them.
Good luck
chef2sail is online now
post #28 of 37 Old 12-19-2007
blubaju's Avatar
yanmar again 3YM30
3YM30 Yanmar do have glowplugs now and unfortunately no more decompression. I am just installing 2 in my new catamaran. Those engines are assembled in Europe, but the block is used for agricultural and industrial machines too, eg, my old boat had 2 3GM30 and only 2 sets of original oil filters as I did not find them anywhre in remote places in Asia, but all other agricultural copies worked perfectly. Other spareparts I never needed in all nine years, engine still running nice. VERY IMPORTANT, after every few hours of running low speed you MUST burn out the build-up, just run at full load for a 10 to 20 minutes. Some other nice advice: www yanmarhelp com (Please add the dots, sailnet does not me permission to post links). No, I am not related to them, but I like that informative page, maybe it helped my engines to last longer ;-)
blubaju is offline
post #29 of 37 Old 12-21-2007
Sabreman's Avatar
Thanks bucho - I've wondered if there was another source for Westerbeke parts. This is my 2nd Westerbeke (W33). On my last boat, we had a W13. Both great engines, but $425 for a water pump is steep! At the risk of going off topic, do you know of a web site where I can crossreference the W33 to a Mitsubishi model? I'm sure that others would find this of use too.
Thanks.
Sabre 38 "Victoria"
Sabreman is offline
post #30 of 37 Old 02-01-2008
Westerbeke non-marine spares
Hi everybody,
We have a Cabo Rico here in the UK, fitted with a Westerbeke 52 engine. I noted that at least one of you had this model, and mentioned that non-marine parts were available, so I was wondering if you know on which engine it is based? At the moment ours is running perfectly, but you never know.
If anyone does have any information I would be most grateful to hear from you.
Many thanks
Steve Moss
stevemoss is offline
cross index between Westerbeke 30 and ford Leyland diesel en NAVIGATORBJORN Gear & Maintenance 11 04-19-2012 10:45 AM
Westerbeke 58 Original to 1983 Boat -- Questions patjj Gear & Maintenance 4 08-28-2010 10:10 AM
Need help YANMAR engine mount Giulietta Gear & Maintenance 20 04-15-2010 01:15 PM
Yanmar 4JH2E air filter element garyroot Gear & Maintenance 8 03-30-2010 08:23 PM
ATF or SAE ? Yanmar 4JH2E / Trans: KM4A TAK Gear & Maintenance 4 11-05-2007 10:34 PM
