SAIL BOX?? - SailNet Community
post #1 of 3 Old 04-19-2002 Thread Starter
SAIL BOX??
Anyone know where I should look for PVC pipe to hold my mainsail and jib for my Hobie 16 and what diameter you think it should be? Any ideas what it costs...I heard it''s pretty darn expensive?
jeffropico is offline
post #2 of 3 Old 04-20-2002
paulk's Avatar
SAIL BOX??
Try Home Depot, Lowes, or similar. The bigger the diamter, the easier it will be to roll, but remember you''ve got to carry it or put it somewhere when you''re done. Perforated pipe (like for foundation drains) will be lighter. (You can also drill your own holes if you like.) PVC is the material of choice because it''s cheap. Can''t imagine it would be more than $3 or $4 per foot- if that.
paulk is offline
post #3 of 3 Old 05-09-2002
SAIL BOX??
Find yourself an irrigation supply company. I use 2 15" pvc tubes for storing sails, rudders, booms, etc. They were purchased several years ago for about $40.00 for 10''. The end caps were about $25 apiece. The pipe came in two grades; pressure or non pressure. I used non pressure as it is much cheaper. Be sure to keep it painted, as UV will make the pipe brittle. Do not carry heavy items such as anchors in your tube, it will fracture.
elf480 is offline
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 02:47 PM
New to Sailing, please Help =) xyris Learning to Sail 19 11-17-2008 08:30 AM
Ketch/Yawl Handling svsymphony Seamanship & Navigation 19 07-05-2008 01:19 AM
Traveler usage? Humpwalker Seamanship & Navigation 22 02-17-2007 10:54 AM
